Q-jet throttle stuck open, backfired, and now won't idle - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-08-2008, 09:04 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Cousin Joe, Must likely you may have one or two bent valves
  #17 (permalink)
Old 09-08-2008, 07:36 PM
Compression Test Results
So I got the loaner compression tester from Autozone on the way home from work, and did the test tonight. Everything came out 150 +/- 5psi. I figured that was probably good news.
I spoke with Sean Murphy today since I got the carb from SMI, and I'm not real knowledgable about Q-jets. He said to try misting some carb cleaner over the carb while running. It slowed down the motor so I think I am running rich. That and the plugs looked 'fuel' wet when I pulled them for the compression test.
  #18 (permalink)
Old 09-08-2008, 07:53 PM
4 Jaw Chuck's Avatar
Pull the hat off the carb and check the secondary needles as posted before.
  #19 (permalink)
Old 09-08-2008, 07:54 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
My thought now is debree in the needle and seat.
Did you use Tephlon Tape anywhere in the fuel supply system?
If so, it partialy disolves, and will keep the needle and seat open.
  #20 (permalink)
Old 09-09-2008, 06:49 AM
I haven't taken a Q-jet apart before, so I was a little hesitant to start there, but it does look like thats where I'm going.
I did use a small amount of teflon on fuel line inlet. I was very careful (or at least I was intending to be) to not put any on the first few threads. That was a last resort, I tried a few different times, but the fuel inlet just kept weeping fuel w/o anything on it.
  #21 (permalink)
Old 09-09-2008, 08:16 AM
Jmark's Avatar
There is supposed to be a thin plastic washer that seals the inlet to the carb body. Maybe you missed it? On the later qjets, it's at the very end of the threads and is easy to overlook.
Mark
  #22 (permalink)
Old 09-09-2008, 08:42 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
Power piston?
Is it possible that the brass power piston was driven to the end of it's bore from the backfire and now it's stuck there? That would make it run rich if it hasn't pulled back into the 'high vacuum' position.
I don't have that much Q-Jet time behind me, any of you Q-Jet gurus seen something like this? If a backfire can knock the secondary rods off the hangers...
  #23 (permalink)
Old 09-12-2008, 05:50 AM
I pulled the top plate off yesterday and everything looked fine, piston, float, needles etc... so I fired it up and it seemed to run fine, took it around the block a few times with no adverse things noticed. It idled, and it would start w/o any problem.
Got in this morning to drive to work, and it flooded out and wouldn't start. Best bet looks like taking the whole thing apart cleaning/blowing and putting back together. Is an internal leak a possibility? I've got to be putting extra fuel in somewhere. Just trying not to go mental while I figure it out.
  #24 (permalink)
Old 09-13-2008, 07:46 PM
RODDER18's Avatar
When it flooded out did the carb over flow with fuel? If so you may have a piece of crap in the needle and seat...
  #25 (permalink)
Old 09-15-2008, 05:34 AM
Got a kit for some new gaskets and went through the carb yesterday. I didn't find anything in the way of dirt/gunk, but what I did find was the clip/needle that attaches to the back of the float was stuck almost out of the seat. I think this could have had something to do with things, as it started up after I had things back on without any major problems. Exhaust smells a little rich, but I'm not fouling plugs, and I was able to drive to work today! Thanks for everyone's help with this, and now I'm a slightly more inclined with Q-jets that I was before this whole thing happened.
