Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Q-Jet wont idle?!?
Old 01-24-2004, 10:23 PM
reborn55 reborn55 is offline
Sounds like you have got a big vacuum leak. are all your vacuum ports in use. large one in back to booster and a couple in front--one to the pcv valve. May be set to lean, metering rods stuck down in the jets, mixture control solenois not working. Would check for vacuum leak or wrong base gasket first.
