Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Q-Jet wont idle?!?
Old 01-25-2004, 08:04 AM
reborn55 reborn55 is offline
make sure the choke unloader is not jammed holding the secondary throttle plate open a little bit./ meant to say the scondary throttle lock out can cause the secondary throttle plate to stick partially open. Will cause similar symptoms
