q jets for B/O/P and caddy throttle bracket - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2003, 07:04 PM
COCHEV's Avatar
i picked up a q jet off ebay that is off a 75 caddy. it is missing the bracket for the throttle cable/kickdown/return spring. it is not your tipical bracket like on most cheby carbs. it seems to have one that bolts on but in this case it is missing. anyone know what i am talking about? if all else fails i will take the throttle shaft out of one of my other q jets and use it. i'd rather find this bracket though. i'll try to attatch a pic to show what i mean. the pic is of another qjet, missin the same bracket
if that doesn't work, here is a link to the auction
buick q jet
Old 07-15-2003, 07:16 PM
All 75 cady,s used a th400 trany. and didnot require a detent lever as the 400 is all electricl down shifted, the switch is mounted on the intake and is activated by the carb. lever hense no hang down lever. Hope this helped, Good Luck. JF
Old 07-15-2003, 07:36 PM
COCHEV's Avatar
thats ok cause i have a stick. but look at the above photo and tell me where the throttle cable goes and return spring?
