QA1 Adventure Series Rod Ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2009, 04:31 PM
Anyone tried these yet. They look like the perfect rod end for a 4 link setup on the street. Check out part number RKP10 and RMR10-16-1P on QA1's website under "off road". Both of these are a rubber injected and can articulate close to 50 degrees (much much more than a urethane bushed rod end). Best part is they are all rubber which means no worries in rain, snow, hail, floods or hurricanes. The only downside is the fact they are 2.6 inches wide (not a big deal if you fab from scratch). I was just about to place an order for 8 XMR10-12 rod ends when I came across these.... What do you guys think.
I should also add you can get a jimmy joint style as well (left side of pic)...
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
Stainless Steel MustangII Tie Rod Ends heyjude076 Suspension - Brakes - Steering 8 10-16-2012 06:35 AM
Custome Urethane Rod Ends joe123 Suspension - Brakes - Steering 9 03-06-2009 06:54 PM
Tie rod ends are too small!!!!! Tom Cline Suspension - Brakes - Steering 6 10-25-2004 05:05 AM
What tie rod ends? FAIRLANE DUDE Suspension - Brakes - Steering 1 01-25-2003 11:24 AM
