Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - qjet choke help?
Old 09-20-2012, 12:13 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
If you remove al the choke linkage the seconday air door control delay vacuum pull off diaphram pot that sets the slight delay of the sec door opening, gets eliminated. You are better off leaving the choke stuff on.
If you won't be using the choke just wire it open.
