Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - qjet choke help?
Old 09-20-2012, 10:30 AM
bygddy bygddy is offline
Originally Posted by F-BIRD'88 View Post
If you remove al the choke linkage the seconday air door control delay vacuum pull off diaphram pot that sets the slight delay of the sec door opening, gets eliminated. You are better off leaving the choke stuff on.
If you won't be using the choke just wire it open.
OK, so if i simply wire the linkage or the actual flap open I don't have to worry about anything else? Fast cam or any other surprises?
So just that and I'm good?
