Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Qjet stumble 360 Amc
Old 08-23-2012, 08:21 PM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
Look inside the carb when you stroke the throttle with the motor shut off. You should see two strong shots of fuel beside the venturis. Maybe a plugged accelerator pump discharge line.
