Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Qjet stumble 360 Amc
Old 08-23-2012, 11:33 PM
UngerMarkus's Avatar
UngerMarkus UngerMarkus is offline
TuckīnīRoller
Thanks for your reply! I just checked the accelerator pump. It looks like it works properly.
The problem is not just a bog or a short power hole. The engine keeps stuttering as long as you keep the pedal pressed. similar to a lack of fuel. When you back off the gas the stuttering goes away and the car accelerates.
