Qjet stumble 360 Amc - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-28-2012, 08:32 AM
UngerMarkus's Avatar
TuckīnīRoller
I put duct tape over the air valves and the hanger to prevent them from opening.
I did what you said and checked the PP with a screwdriver. It seems to work smoothely.
As for the casting number, Iīm gonna check that and let you know. As far as I know itīs a brand new Jet Carb set up for Smallblock Truck engines.
  #17 (permalink)
Old 08-28-2012, 08:36 AM
Ok you do know the secondaries still open, even when you tape the air valve off?
  #18 (permalink)
Old 08-28-2012, 09:19 AM
RWENUTS's Avatar
How many turns on the screw are you at on the secondary air valve. Measured from zero adjustment. I tap on the air valve and when it won't try to close I call that zero.
  #19 (permalink)
Old 08-28-2012, 01:38 PM
TuckīnīRoller
Thanks for your replies, guys!
I did what you suggested me and checked the PP with a screwdriver. It works nicely.
Unfortunately I forgot to write down the casting number. But it is a Jet performance light truck stage1 carb.
The APT was screwed out 4 turns. I tried everything from completely seated to 5 turns out in 1/4 turn increment. But it didn't make much difference. I also advanced the ignition a bit.
In D it drives badly. When I locked it in first gear it accelerates good as long as you open the throttle progressively.
When I floor it, it stutters badly and does not pick up speed. When you let off the gas a bit, it accelerates again.
  #20 (permalink)
Old 08-28-2012, 01:53 PM
TuckīnīRoller
From the point where the spring doesn't close the air valve anymore I loaded the spring with one full turn.
  #21 (permalink)
Old 08-28-2012, 02:36 PM
RWENUTS's Avatar
Getting stumped!!
Blow some carb cleaner thru the air bleeds that are located between the choke housing and the secondary air valve. In photo 2 in the link you see them 4 tubes that are attached to the top plate. Best to remove the top plate to check they're clear. I found one once that was pinched off.
You could try blowing thru them without lifting the lid.
Diagnostic Dilemmas: Servicing Quadrajet Carburetors: Underhood Service
AMC/Jeep 360 Gun Laker Engine 0 08-17-2011 09:48 PM
AMC 360 v8 jim martin Hotrodding Basics 1 12-16-2010 10:57 AM
amc 360 fullof questions Engine 6 09-05-2008 04:55 PM
360 Mopar stumble... BigBlockBanjo Engine 2 04-20-2007 11:12 AM
AMC 360 in a '92 metro? 73 Nova Guy Hotrodders' Lounge 35 02-26-2003 11:23 PM
