Has anybody tried one of these tools? I'm looking for first-hand experience that knows if they work or not. I have 2 qjets that I would like to salvage - but both are severely warped in the main body and air horns. I have quite a bit of money (and tuning time) tied up in one of these two carbs.
wow, for that kind of money I would think you would be able to build something similar for half the cost. I'm not sure how that would work though, it doesnt look like much for $250.
I would be very suspicious of it since it comes from JC ******. Did you happen to notice it said for use with carb kit #****? What you want to bet that carb kit has thicker gaskets.
Says “Will ship by 09-09”. Almost 2 months? Punched in the item number for the: “For use with Quadrajet Jet Carburetor Repair Kit (Sold separately. Item # ZX266889). Got no return on the number, might be a partial p/n for a rebuild kit?
If the body is any further gone than what will clean up w/a solvent wetted piece of fine emery paper on a large, flat sheet of glass, I would call it junk anyway- but I've YET to find a body that wouldn't clean up that way, in the first place...
I don't even check the tops- it goes where the body "tells" it. The throttle plate gasket is so thick, it'll compensate for dam near anything.
I've already fixed the top as you described - here is the "before" picture (yeah, I know, the mounting stud nuts were over tightened :spank: ):
This isn't the best picture to show how the body of my qjet is cupped, but both the front & rear dip down quite a bit. I thought I overtightened these (and I'm sure I did at some point), but the original carb looked very similar - and I didn't touch that one.
I know that the air horn can stand a good amount of grinding on a table sander. You could try asking Cliff Ruggles at www.cliffshighperformance.com/quote.html that guy is wicked smart with the qjets!
That's some serious out of plane! I can't imagine what besides a lot of heat along w/some vicious tightening would get one that far out. It could be a poor casting, not stress relieved possibly- but that's a WAG.
Other than to try to make the base gasket conform to the irregularity of the body of the carb by removing gasket material from the high areas, I don't know what you could do- there's no real way to work on removing the cupping on the throttle plate side of the body with the main wells, locating pins and etc. in the way.
In any event, that carb must be special to you, that you'd even be considering reviving it!
I spent months and countless hours rebuilding this thing. I invested a heap of money in the carb getting the tune correct. The idle and idle transition circuit is about perfect for my cam (which was no small feat on an emissions era carb). At this point I would like to lean out the primary jets & run it.
So, I guess I'm just sticking with what I know. My new Holley 4150 is OK, but I miss the Qjet...
Once you have a Q-Jet tuned in it's extremely hard to turn it loose. One of my best buds in high school was a Q-Jet guru. He took delight in showing us how a Q-Jet could perform.
Vince
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
