Q's on 454 marine block - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2011, 06:44 PM
bigalow's Avatar
A 454 4 bolt main engine out of a boat .030 but dropped a valve and needs one sleeve. Is this any good?
My intention is to build it and put it in my truck
Old 10-14-2011, 07:13 PM
327NUT's Avatar
It's as good as the machinist doing the work, a properly installed sleeve will work just fine.
Old 10-14-2011, 07:52 PM
X2 on what he said.
Old 10-14-2011, 09:18 PM
bigalow's Avatar
Is a marine block any different?
Old 10-14-2011, 10:24 PM
techinspector1's Avatar
Wiki Edits: 326
There are certain differences between automotive and marine applications, but I can't see how a sleeve in a marine motor would act differently than a sleeve in an automotive application. Check with a certified marine machinist.
Old 10-14-2011, 11:22 PM
bigalow,
The engine doesn't know it is in a marine application.
The only thing to watch for is that after the sleeve is installed and bored out to match the other cylinders is that the cylinder/s next to the sleeve need to be honed straight.
Also check the connecting rod to see if it got a little bend in it. If it is bent replace it. I think I would just replace it when you have the new piston installed.
If you plan on running this engine in a street application then the camshaft will need to be changed also. The marine engine must produce horsepower as soon as the throttle is cracked open in order to propel the boat out of the water and onto "plane" with only the bottom third of the boat touching the water. With a camshaft producing that kind of torque the engine will not pass smog testing.
Good Luck
Scholman
Old 10-15-2011, 07:06 AM
bigalow's Avatar
thank you I will get a new rod plus a new torque cam.
Would a turbo 400 be a good choice for a trans??
Going in a 54 pickup w 3.23 gears
I have read the TH series trans's rob alot of HP 25%
Old 10-15-2011, 07:32 AM
bondo's Avatar
Ayuh,... The blocks are the same, they're just assembled differently...
Old 10-15-2011, 11:02 AM
bigalow's Avatar
I'm a MOPAR MAN and this is my first big chevy in a Hotrod- Excited.
They say "once you go Mopar you never go Chevy" But maybe its the otherway around??? HMMM?
Old 03-27-2013, 11:51 PM
Wet 454
There is difference in a marine Vs automotive. First of all marine blocks are 4 bolt mains, added piston to wall clearance, more than likely big port heads depending on hp rating 330 and up are the big ports, and they also have different cam grinds. they will use oil in a street application do to the added clearance. In a marine engine the block stay's much cooler than in a automotive application and the piston stays much hotter. That's why they and the extra clearance. Marine engines are set up to run at higher sustained loads at 3000 to 4800 rpm's at over 50% throttle and up to wot for long periods. Also cast with a higher nickle content.
engine identification 327 marine block blight Engine 24 07-15-2014 09:00 PM
marine block bajavr Engine 2 06-07-2011 09:27 PM
351 marine block nitrous_69stang Engine 2 02-07-2005 03:50 PM
Chevy Big Block 454 Marine heads 71 nova Engine 4 09-03-2004 06:08 PM
