Jester, where dissimilar metals react when in contact w/each other is an electrical reaction called "galvanic reaction". It can cause corrosion of the zinc the carb body and airhorn is made of. Aluminum is only used in the baseplate of a Q-jet.
So the white deposits are zinc oxide or zinc "rust". It forms when the dichromate coating is damaged or removed. The thing w/removing the corrosion is it does tend to return if conditions favor it, so the best bet is to keep water away from the carb, drain it and use mineral spirits inside when stored, and don't make matters any worse by using strong acids or mechanical means that removes the zinc dichromate finish. I'm in contact w/Caswell Plating to see what can be done about replating/restoring the chromate finish on zinc carbs. This is much less a case of wanting a factory looking finish than it is making the carb as corrosion resistant as it can be. If there's any interest I'll post what I find out. |
Hope I didn't stir up anything by posting the last time. I thought it might help someone. Jester, you mentioned contacting a carb company. I did, and Holley said they can repassivate the zinc carb body/airhorn. I don't recall the exact price, but it was a LOT more than I was willing to pay in the early 90's. There are guys who sell rebuilt carbs on eBay that will work w/an individual to refinish carbs. I have zero experience w/any of them so cannot comment further than to say they exist. Right now, I'm hoping for a workable solution from Caswell. Last edited by cobalt327; 01-23-2012 at 08:00 AM. |
I wasnt even going to post, I was checking for a part for a Quarajet on line and this hotrodders thread came up!!! And the first thing that hit my mind was some kid picking up toilet cleaner and pouring it into his carb and destroying it like an edelbrock or carter or etc, Not to mention a kid taking a wiff of some of the stuff mentioned and being rushed to the hospital for chemical pneumonia and lung tissue damage!! Even vinegar can break down aluminum in a very short time!! This long speech isn't really meant for you because I read all your posts and threads and Know your knowledgeable ! And you call it like it is! To you people that dont know Even the aluminum foil we cook on has a protective coating to stop corrosion while its in the box on the shelf and it would turn white and powdery without it! I dont think what you wrote above was to give me a class Or correct me on what I said ( if you meant it that way I didnt take it that way,I hope you weren't) I hope you were pointing out something I left out >I know what galvanic reaction is. Electrolysis is when you purposely apply current , Galvanic is a self occurring process When too dissimilar elements react. If any one posted electrolysis I knew what they meant (or if I said that! I knew what I meant too!!) LOL The people on here and the suggestions they made about the caustic materials wouldn't know the difference anyway ![]() Cobalt is right on every thing he said! ( and I used Mystery oil to store carbs many years ago because I was taught that way, It contained Whale oil back then maybe its different now! I didnt use mineral spirits Because it swelled rubber o ring Etc, IT might be different now ( mineral spirits might be a little gentler now< and theres not much made out of rubber any more) Cobalt If mystery oil is bad I need to know Im not too old too learn! Im interested in the Caswell plating even if I am retired (I'll still be getting grease under my nails Chris |
Can be zinc oxide or aluminum oxide in there.. Man! what a discussion..people get flustered on here.... Ps. I only drink the Coca Cola |
Double vision: I wasnt bashing you, You posted a very good Question!! ,It was the answers you were getting!! I dont push any products on here especially carbs (To each his own) If you read all my posts youll see I dont push anything !!!! If you took this as a bash!!you havnt read anything that was dumped of mine or it was so bad a bashing it didnt even make it to the dump! Ive been threatened to be expelled in the past. Now Im very careful not to offend Any one and I met a lot of good people here I'd hate to lose that.
If you have something to post that I posted Bashing you! put it on the lounge title it Attention Chris: and let every one read so every one can see And I ask the monitors to let it pass.And dump it later ( Im going to read all my old posts now) If your blowing smoke Ill probably get thrown off here later Im not offended by this so please dont dump it. Ill be back in a bit and if I'm wrong I'll apologize, but I dont think Ill have to! Look monitors Im smilingThe only one I see that you could misunderstand Is when I said here that I was laughing at your post When I should have said thread and I was laughing at the answers you were getting not at you ! If you find any thing else you missunderstood Ill be watching the loung If you dont want to post on the lounge message me. Last edited by painted jester; 01-23-2012 at 02:43 PM. |
The post your talking about is on B.G. carbs taken over by Holley you weren't bashed I even commented that Quadrajets were a good carb I think you read that post wrong!! I posted carbs I had trouble with! I dont remember Quadrajets (I never had that many problems) were even mentioned! I did say there may be a problem with your supplier from my personnel exp. I even said I didnt doubt you had those problems you stated>
You stated: "If I were Technical I might care" on this thread you think this is Technical . Its basic high school stuff. No one has to bash you when you write stuff like that. You were looking for something and took my words out of contexts to fit your rant. I think you need to cool off and re-read! I also think you read it expecting to get what you thought you read. I did that myself when I was younger. Cobalt was on that thread so was topwrench If they message me and get the same meaning as you did on that post I'll apologize. Or maybe the monitors will let it pass If they post it on this thread . Even though its not the place. Jester |
Jester,I read all ur posts too n dont think u based anybody!
I dont care what carb people use,but if there is a question about a carb doin damage to a motor I build I dont use it.Thats what I was trying to say. On boats we use galvanic isolators all the time to prevent electrolisis,we also use zinc anodes so they will get desroyed before Aluminum or Brass engine components will. So anyway I think everybody needs to cool it,I also read this whole thread and he got some really good info here. |
AFAIK MM oil shouldn't hurt anything. I mentioned mineral spirits because that's what I've used in the past, but even being left dry is an option as long as it's bagged w/a dessicant.
I'm not a fan of storing a carb fully built. If possible I'd rather keep it apart so the pump piston seal isn't left sitting in the pump forever and a day waiting to be used. Plus who knows exactly what jetting and power piston spring may be needed, unless it was a spare carb for an engine that wasn't going to have any changes made to it that would effect the carb tune. The reason I brought up the galvanic deal was I read acid somewhere, just wanted to set the record straight on that. More damage is done by improper cleaning than any galvanic action anyway. Once the zinc chromate finish is gone (I mistakenly called it dichromate*) it's a matter of time until the underlying zinc corrodes. * If anyone cares, I was told by the owner of The Carburetor Shop that zinc dichromate is a process that uses electricity, which the zinc chromate carb finish doesn't use, it's dipped into a solution w/o any electricity. Because the carb is zinc it needs nothing but a thorough cleaning then the chromate dip. A steel part would need to first be zinc plated, then the chromate applied over that. But the bottom line according to the Carb Shop is to forget trying to reapply a chromate finish. To do it "right" requires hydrochloric and nitric acid (both readily available), and chromic acid- which is one of those chemicals on the list of carcinogens (cancer causers) and apparently might as well be made of unobtainium. Which leaves us w/either sending the carb to Edelbrock (who apparently have found a workaround or have the proper equipment and EPA certification to do it in-house) or to use whatever household/shop methods to rid the carb of it and hope it doesn't come back worse than before. |
Well guys Im the proud owner of a Fish carburator,had on a shelf for years,its apart n still lokks like the day i got it.
Remember Bob Fish? |
Have any photos of this deal?
Thanks for the info, Cobalt
Jester |
eBay has an "experimental" Fish (link below). No idea if this is anything like the one topwrench has. I don't know squat about them except the legend about Fireball using one, and I think I recall it being when Smoky was doing his race cars- but I could be mistaken. I hope TR's able to show it to us all.
http://www.ebay.com/itm/RARE-FISH-Ca...item3a6f430dfe |
I never saw one before , very interesting thanks: Chris Last edited by painted jester; 01-23-2012 at 07:24 PM. Reason: hit wrong button sorry |
| Quadrajet | PyroManiacUSMC | Engine | 3 | 12-17-2011 06:04 PM |
| Converting from external choke quadrajet to electrical choke quadrajet | silentpoet | Hotrodding Basics | 4 | 10-03-2011 01:38 PM |
| quadrajet help!!! please> | 1977impala | Engine | 3 | 05-17-2010 06:37 PM |
| help on id#s on quadrajet | hottrodz | Engine | 4 | 12-21-2006 05:33 PM |
| Quadrajet | novatech | Engine | 16 | 04-24-2003 11:44 AM |
