I just had my carb rebuilt. It is a 1980 454 carb going on my mild 350. I can hear this sucking sound coming from the carb. If I close the front primary plate the sound gets quietter. What does this noise mean. Is this noise normal for quadrajets.
Either a vacuum leak or a fitting not plugged. Use some WD 40 and spray around the carb, if you notice a difference that will be the place its leaking. Some use either but you have to be very careful.There is a similar posting like this 3 pages away.
Luv the smell of NITRO in the morning. |
turn on the propane torch (don't light it) pass it over the top of the carb and listen to the idle change. pass it around all vaccume lines, if the idle goes like the test, you found your leak. mikey
I took some carb cleaner and sprayed it all around the carb and the idle did not change at all. The sound is coming from inside the carb. Like I said before, when I close the front primary plate the sound goes away or is really quiet. What would cause this sound inside the carb?
I hate to say it but you could save yourself some headache here. If the performance is bad still and you're sure it's the carb replace it with a Holley or Carter. R-ster Q-jets are notoriously difficult to rebuild and tune. They were intentionally engineered that way to prevent people from changing the factory settings. Every carbed GM vehicle I've owned that had a Q-jet on it got changed quickly. If you have access to a second hand speed shop in your area, you can usually pick up a decent Holley for $100 or so. Just my 2 cents.
Actually the performance from this carb is awesome. I had an edelbrock on my motor before and I had all sorts of problems. I switched back to the old quadrajet that was rebuilt by me and the driveability tech at my shop and it seemed to free up a lot of horsepower. It runs way better with the quadrajet on it. He also helped me tune it. I asked him about the noise and he said it was normal. I don't think it is normal. I don't know though, maybe it's just me. I'm not complaining about the performance, just the noise. It does sound like a huge vacuum leak, but I don't think it is. I don't know what the noise is. I guess I can deal with the noise since the car still runs like a dream. Thanks for the help guys.
The Quadrajet is one of the best carbs made. I love all you guys that, at the first opportunity, you replace them with Holley's or whatever you think is better. It just means more free Q'jets for me. Thank you.
Q-Jets are a great carb. You can't beat them for the street. You can get excellent fuel economy with the smaller primaries and awesome performance with the huge secondaries. I can't think of what your problem is but I can put you in touch with someone whoe might be able to answer your questions.
owner@thecarburetorshop.com |
Sorry for the sarcasm up there, But Ive heard the "Just junk it and get a Holly/Edelbrock" thing way too many times. If it runs great and idles well, without hearing it firsthand, I would say you dont have a problem...I for one think they are a blast to rebuild, not hard at all. Plus since used ones are usually cheap, you can play around with different jets and metering rods without breakin the bank! Check out the KB, all kindsa good Q-jet info in there!
If it helps you any, my dad has an 83 C10 truck with a quadrajet. It does it at idle a little, but really does it when you put your foot about 1/4-1/2 way down. Shuts up when the secondaries come in. He has had no problem from it in 10 years, and hasn't had to rebuild the carb once since he got it. I'm not saying it's supposed to do it, though.
I myself perfer Q-jets, as already said, for the street they can`t be beat. but one thing you can do to test this sound, is grab the throttle linkage, and move it, if the noise stops or gets less, you found the problem. Q-jets are notorious for wearing out the primary throttle shafts, I`ve seen many that will make the noise you discribe and wiggle the linkage and it stops, if the carb has over 100,000 miles on it, you can bet it`s wore out, the solution is to have new bushings installed, or find another base plate that isn`t as worn, but, as the years went by the base plates changed in design, so try and get one that is close to yours as you can find. Good Luck.
