Quadrajet Carb rebuild....parts interchange with another junk carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2006, 02:04 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I just started rebuilding my quadrejet carb...After taking it apart I found a few problems, like a bent metering rod. I was wondering if I can take one out of my junk carb. The one I am rebuilding is a 1973 oldsmobile 455 750 cfm, I think, #7043252. The junk carb that I want to steal parts from is from a late 70s chevy 1 ton truck with a 454 800cfm with the pullotion crap #17056212. Are all or most of the parts interchagable like the baseplate or throttle body and the metering rods?? (BTW it is going on chevy 350)
Also the rebuild kit that I bought did not come with new springs for the accelotor pump, power piston etc.? I just reuse my old ones or is it common that a rebuild kit comes with new springs.
Thanks
Old 07-31-2006, 10:31 PM
I think the metering rods are different between the 7-digit and 8-digit carbs. Probably more stuff, but I can't say for sure.
You're supposed to re-use your pump and power piston springs.
Old 07-31-2006, 10:44 PM
Jmark's Avatar
Unless the rods are the SAME length and the SAME diameter, I would not swap them. The early rods are shorter than the later (170*****) carbs. Try to very carefully straighten the rod, usually lightly tapping it with a small hammer with the rod on a hard surface. They are fairly soft so don't try to bend it with your hands or pliers.
Re-use the springs like Jim said.
Mark
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
quadrajet Where do these parts go? inetj Engine 5 09-27-2004 08:34 AM
Transmission rebuild parts list. 4 Jaw Chuck Transmission - Rearend 2 06-29-2004 08:04 AM
65/66 impala parts interchange??? swain66 Body - Exterior 0 03-25-2004 06:14 PM
small block ford parts interchange k-star Engine 3 01-16-2004 09:35 AM
