Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - quadrajet cfm
Thread: quadrajet cfm
Old 07-29-2013, 02:46 PM
lmsport lmsport is online now
The air valve is opening too fast meaning the tension on the spring should be increased.
Turn the spring adjusting screw another 1/4 turn. Make sure to have the screw driver in the adj. screw when loosening the lock screw.
25" of vacuum at 1000RPM means you have a really mild camshaft.
Have you checked the air fuel ratio indications on the spark plugs?
