I've done plenty of them and I just run a wire from the fuse box that has 12 volts with the key on. Like stated take out the gasket betweem the choke coil ans housing. Also, be sure to plug the vacuum port in the choke housing that pulled the hot air up from the u tube that went into the intake.
