-   -   quadrajet choke problem (http://www.hotrodders.com/forum/quadrajet-choke-problem-225372.html)
pilatus 10-25-2012 08:27 AM
86 GMC p/u with 350 with quadrajet. Engine starts, races and then quits. Prior to this behavior engine starts rpm wavers up and down then idles. p/u driven once a month.
against all odds 10-25-2012 11:43 AM
Maybe the vacuum and/or mechanical advance is not working?
If the engine starts runs, races and then stops, to me that means you got fuel. I don't know if the choke is the problem here.
pilatus 10-26-2012 03:15 PM
thank you for the reply. I found some videos on YouTube and learned about the wire to the choke coil. I traced the wire behind the distributor and found it shredded by a rat. Replaced the wire and p/u runs OK.
boothboy 10-26-2012 06:15 PM
There's got to be a Rat Motor joke in there someplace.
BB:thumbup:
