quadrajet choke problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2012, 09:27 AM
86 GMC p/u with 350 with quadrajet. Engine starts, races and then quits. Prior to this behavior engine starts rpm wavers up and down then idles. p/u driven once a month.
Old 10-25-2012, 12:43 PM
Banned User
Maybe the vacuum and/or mechanical advance is not working?
If the engine starts runs, races and then stops, to me that means you got fuel. I don't know if the choke is the problem here.
Old 10-26-2012, 04:15 PM
thank you for the reply. I found some videos on YouTube and learned about the wire to the choke coil. I traced the wire behind the distributor and found it shredded by a rat. Replaced the wire and p/u runs OK.
Old 10-26-2012, 07:15 PM
There's got to be a Rat Motor joke in there someplace.
BB
Converting from external choke quadrajet to electrical choke quadrajet silentpoet Hotrodding Basics 4 10-03-2011 02:38 PM
quadrajet electric choke badmystur Engine 7 09-13-2010 07:25 AM
remove choke from quadrajet? 1964_442 Engine 5 10-16-2009 09:27 PM
Quadrajet electric choke. kegross1 Electrical 7 09-21-2009 09:01 AM
quadrajet w/electric choke ace1 Engine 6 12-22-2002 01:09 PM
