Quadrajet E4ME question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2013, 07:41 AM
HI
Anyone knows if a quadrajet E4ME electronic controled can be used in a early v8 that not have computer. Can I just install it without the wirings?
thank you
Old 06-22-2013, 11:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by rockabilly66 View Post
HI
thank you
In a word- no, at least not as-is. These "E" carbs can be set up to run acceptably well for drag racing w/o a computer (limited in how much part throttle use it'll see, like driving back to the pits), but for a well mannered street engine you will want a non feedback carb.
Old 06-23-2013, 10:12 AM
The answer is, yes you can, but fuel economy and performance will absolutely suck. I'm somewhat embarrassed to admit that I've done this. The secondary side of the carb is not computer controlled, so WOT works fine, so long as you understand that the secondary air valves are limited to only open about 70 deg instead of the full 90 deg. The problem is the primary side. The primary mixture control uses solenoid activated metering rods that are pulsed in and out of the jets to control the mixture. Without the computer, they go full rich. The car will run, but it will be WAAAAAY rich at idle and part throttle. You cannot convert to the old style jets and metering rods.
Bottom line is, don't waste your time trying it - I already have.
Old 06-24-2013, 08:10 AM
thank you very much!!
Old 07-09-2013, 11:58 PM
4MV, or even M4M qjets are $20 on ebay.. throw that E4ME in the nearest lake!
I love qjets... sure do miss them for street driving!
Old 07-10-2013, 04:42 PM
LATECH's Avatar
The E4ME was a fair carb and wasnt excessivley difficult to set up.
Not an Ideal fuel control, such as EFI but not bad for the day.
The economy could be pretty decent on them along with lock up converters and such, provided the electronic control and sensors were all working.
By todays standard, they dont even make a good doorstop,
However, if you own a mid 80s G body and want it o pass emission inspection in Pennsylvania, you need to keep it OE underhood as far as emission devices go.
Fact is stranger than Fiction
Old 07-10-2013, 11:46 PM
makes me glad I live in state that doesn't do emissions testing.. tho we REALLY do need a basic safety inspection.. some of the things you see here in Michigan will just make you shake your head in disbelief!
quadrajet question jak327 Engine 2 04-24-2010 09:51 AM
quadrajet question? hemi joe Engine 4 10-24-2009 10:34 PM
Quadrajet Question super_silent Engine 9 05-27-2008 08:08 PM
Quadrajet Question 1979T/A Engine 3 04-21-2008 07:52 PM
Been a while, have a Quadrajet question... offroadin Engine 6 02-12-2008 08:16 PM
