-   -   Quadrajet electric choke. (http://www.hotrodders.com/forum/quadrajet-electric-choke-11066.html)
kegross1 09-17-2002 10:29 AM
I have a 79' Malibu with a Rochester Quadrajet carburetor and electric choke. The choke isn't pluged-in and I'm not sure how it should be wired. Any help will be appreciated.
72 chevy 09-17-2002 05:57 PM
Well, what you need is power with ignition switch on, confirm that you have no voltage with switch off, with test light or meter. do you need to run a new wire, or is it just disconnected?
[ September 17, 2002: Message edited by: 72 chevy ]</p>
kegross1 09-25-2002 12:10 AM
It looks like I need to run the wire. I don't think the car had an electric choke to begin with.
Thanks for the reply.
78chevy malibu350 09-17-2009 02:46 PM
need an electric choke choke
i just did an engine swap and found out that my electric choke is bad and i am having trouble finding one for my quadrajet carb on my 350 chevy if anyone knows where i can find one let me know
pitts64 09-18-2009 03:57 AM
I always remove the whole choke assembly, it's not needed.....
JohnTN 09-19-2009 07:14 PM
My car sure starts easier with a choke.
302 Z28 09-19-2009 09:43 PM
They always do. :D
Vince
MOTOR HEAD 09-21-2009 09:01 AM
Just run a new switched wire feed to the choke & make sure it gets a full 12 volts. ( Don't use an accessory feed ) :welcome:
