Quadrajet electric choke. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2002, 10:29 AM
Post Quadrajet electric choke.
I have a 79' Malibu with a Rochester Quadrajet carburetor and electric choke. The choke isn't pluged-in and I'm not sure how it should be wired. Any help will be appreciated.
Old 09-17-2002, 05:57 PM
72 chevy's Avatar
Post
Well, what you need is power with ignition switch on, confirm that you have no voltage with switch off, with test light or meter. do you need to run a new wire, or is it just disconnected?
[ September 17, 2002: Message edited by: 72 chevy ]</p>
Old 09-25-2002, 12:10 AM
Post
It looks like I need to run the wire. I don't think the car had an electric choke to begin with.
Thanks for the reply.
Old 09-17-2009, 02:46 PM
need an electric choke choke
i just did an engine swap and found out that my electric choke is bad and i am having trouble finding one for my quadrajet carb on my 350 chevy if anyone knows where i can find one let me know
Old 09-18-2009, 03:57 AM
I always remove the whole choke assembly, it's not needed.....
Old 09-19-2009, 07:14 PM
My car sure starts easier with a choke.
Old 09-19-2009, 09:43 PM
302 Z28's Avatar
They always do.
Vince
Old 09-21-2009, 09:01 AM
MOTOR HEAD's Avatar
Born to Wrench
Just run a new switched wire feed to the choke & make sure it gets a full 12 volts. ( Don't use an accessory feed )
