Quadrajet a/f mixture screw setting - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2007, 11:53 AM
I am having trouble setting up my quadrajet on a 74 L-82 (350) vette. how many turns out should i start at on the mixture screws? and how do i go about tuning it from there? I do have a vacuum gauge but am not sure what to look for. anyone good at this?
Old 07-05-2007, 12:54 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
I place the vacuum gauge on a constant source on the carb and set the idle so it will run, then adjust one screw at a time until you reach the highest reading. Lower the idle until until you have about 700rpm then adjust the screws until you get the highest reading again (should be running smooth!) now turn up the idle to specs and place in gear with foot on brake, should still be smooth.
Try that and tell what you get!!
Old 07-05-2007, 01:56 PM
DoubleVision's Avatar
Solid nailed it.
Old 07-05-2007, 08:11 PM
Start with the screws about 3 turns out from bottomed, maybe 4, and be sure you don't screw them down tight when you bottom them. The metal in there is kinda fragile.
Old 07-05-2007, 08:15 PM
Your on it! It will take some time. You want the highest vacuum you can get.
Mark.
Old 07-06-2007, 08:58 AM
Thank you for helping now i guess its up to me to get it right. after the screws have been turned in how far can i expect them to have gone? (just for reference) and when you say one at a time does that mean i work only the left until the vacuum is high befor switching to the right, or alternate between the screws giving them each only a 1/4 turn or so then going to the next. i know i am a pain but i really want to nail this. Thanks again
Old 07-06-2007, 09:13 AM
Yep. Alternate. Go from one to the other, It takes some time. When you get the highest vacuum on one side go back to the other and so on. Good luck.
Mark.
A/F idle mixture ?? voodoosurfer Engine 3 10-28-2005 10:47 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
QJet Initial Idle Mixture Setting JohnTN Engine 4 06-10-2005 01:31 PM
Idle Mixture Screw Plugs kringold Engine 1 05-10-2005 04:07 PM
Holly mixture adjusting screw FASTMONTE Engine 3 02-05-2004 07:38 AM
