Quadrajet geometry correcting plate for 700r4? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2013, 07:22 PM
Ok I am sorry if I am beating a dead horse. I am having issues with my cable setup. I am running a 454 w 700r4 and the carb is a quadrajet my issue is the stupid geometry plate that attaches to the carb. I know they make aftermarket ones for holley, edelbrock, carter but yet to have seen one for a quad. Can someone help me please, I am so close to being able to drive the car in and out of the garage so i can start doing bodywork. Any input would be great! If someone knows how to fab one Ill pay to have one made lol. I know how important the tv cable is so I know not to drive it until all this is taken care of.
Old 02-23-2013, 11:56 AM
RWENUTS's Avatar
Is your quadrajet a manual or automatic tranny carb?
Auto tranny one has the bracket already on it.
Old 02-23-2013, 12:46 PM
It's an automatic but it does not have the geometry plate for the tv cable
Old 02-23-2013, 12:59 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Here is a cartoon complements of Art Carr.
ID:	71657   Click image for larger version
Fact is stranger than Fiction
Old 02-23-2013, 02:23 PM
I do not know where to begin with that diagram. I am sorry for my ignorance...
Old 02-23-2013, 02:27 PM
RWENUTS's Avatar
Search 'Google Images" for quadrajet tv cable and pick your poison.
Old 02-23-2013, 02:38 PM
Crosley's Avatar
Wiki Edits: 1659
Near middle of page are fotos. May help
Clik Here
Old 02-23-2013, 02:46 PM
Thanks for some help I am actually away from the vehicle and cannot take a pick of my linkage so when I get back ill take a pic and post it it to thread. Those pictures on that site are good but the one picture shows the tv cable hooked to a hole in carb exactly opposite of the return spring hole. If I remember correctly I don't have that same provision for the cable just the return spring hole.
Old 02-23-2013, 03:13 PM
RWENUTS's Avatar
THen you must have a manual tranny quadrajet!
Excellent link Crosley!!
Old 02-23-2013, 03:23 PM
Then it must be!!! Motor came from automatic truck! Just asking for help. I'm sure I'm not the only one who has asked or been curious.
Old 02-23-2013, 08:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Q-jet carbs were used on some TV cable transmission equipped vehicles, using one of them will only require a bracket. A carb used w/a TH350 detent cable has slightly different geometry.
Info/links: TV cable
Old 02-24-2013, 06:11 AM
artsvettes's Avatar
The later style quadrajets that were behind 700r transmissions are a good source. I swapped out the shaft of a 87 monte 2004r carb in my 77. It is a pain but it was less taxing on the brain.
Old 02-25-2013, 01:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In some cases (on later model carbs), the baseplates can be swapped out- but you have to watch out for a few things, mainly that the gaskets are identical and that the idle air bypass orifices are similar. The bypass sizes aren't a big deal, they can be resized as needed.
Old 02-25-2013, 07:24 AM
Thank you all for all your help!! I had a donor carb which is an auto so I'm going to attempt to just swap shafts because it has the linkage I need. Any precautions? Thanks again.
Old 02-25-2013, 09:04 AM
artsvettes's Avatar
If it is not off a car with a 2004r or 700r4 trans, it won't work the geometry is diffrent
More Quadrajet Stuff-- Question about polished throttle plate clicketyclack Engine 6 07-17-2010 05:23 AM
Quadrajet adapter plate Mertz Engine 12 04-08-2008 08:52 AM
700r4 cable geometry out of whack 1chevelle Transmission - Rearend 3 11-18-2007 06:59 PM
correcting speedometer Mitch Arivett Transmission - Rearend 3 02-20-2005 09:53 AM
Correcting Weld Warpage? TurboS10 Body - Exterior 8 01-31-2003 05:47 PM
