Quadrajet, high idle with warm engine - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-29-2011, 07:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by cobalt327
Temporarily remove the vacuum hose from the vacuum choke unloader shown in the box below. Plug the vacuum port at the carb and see how it behaves w/o the unloader hooked up.
Did you do this???
  #17 (permalink)
Old 04-30-2011, 12:38 AM
I did not change anything in that sqaure if thats what you mean. Somethinh wrong?
  #18 (permalink)
Old 04-30-2011, 09:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I asked you to perform a simple task- as outlined for the second time in the post above. If that's not clear enough for to you to follow, I guess we're at an impasse.
  #19 (permalink)
Old 05-01-2011, 03:17 AM
ow,okay! I am very sorry for misunderstanding. Havent gotten to that yet. Its my wives car and she drives it daily. We dont have garage and the wetter hasnt let me do any more research the last days. I'll check this afternoon and get back to you.
  #20 (permalink)
Old 05-01-2011, 12:08 PM
alrighty,
checked the choke unloader. unplugged it...first put a hose on it and sucked on it, but the unloader doesnt move...
I then plugged the connection to the carb and drove it a bit. But no change.
Still got the annoying high idle when I dont kick the throttle...
I made two short films (As requested) hope you guys can see what I mean...
first one without engine running (sorry movie is upsidedown)
http://www.youtube.com/watch?v=lAIkJiofIAA
second one with engine running (sorry again upsidedown)
http://www.youtube.com/watch?v=3ZKK1kIdVZ4
As you can see it is only a very little bit that the throttle stays open.
and it's almost like the little play there is in the linkage seems to be gone when the engine is running. I can not feel any play when the engine is running.
  #21 (permalink)
Old 05-01-2011, 12:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
So you're half way there. Take the carb number down from the side of the carb and hie on down to the parts store, spend $12 on the unloader and replace it.
  #22 (permalink)
Old 05-01-2011, 12:20 PM
can you explain why? what does the unloader do? and how would it keep my idle high? unhooking it didnt make any difference. Can you help me with this. I have very little knowledge on carb.
  #23 (permalink)
Old 05-18-2011, 02:45 PM
I finally found the cause why my carb will not return to full idle postion...
I installed new dual springs...like they are supposed to be. BIG and THIN spring combo. These are a lot stiffer and have no problem returning the lever to the idle position.
So my problem was caused by weak springs...the ones that were on before did almost not offer any force when near idle position. while these new springs do...
as you can see in idle postion they are allmost fully relaxed...so PROBLEM SOLVED...thanks guys for all the support!
  #24 (permalink)
Old 05-19-2011, 05:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Now if you replace the unloader you'll even have the secondaries working right. And take a few minutes (hours?) to clean that engine up. You need to seal the intake bolts where the oil is pooled on top of the intake. Unless that's fuel, in which case the problem might take care of itself. Just be sure you included a fire rider on your insurance policy.
Screws in the ends of short pieces of vacuum hose is not how extra ports should be blocked off. If you were to pull those hoses off and pull a vacuum on the carb end, most would leak right down. The cheesy HELP section rubber plugs don't last, so either use good plugs or head down to the boneyard and find some OEM plugs to use.
So, what happened to the whole "tight linkage w/engine running, loose w/engine off" deal. The springs didn't fix that.
Rough idle, high idle in park, stalls in gear.. Help! ratmaro Engine 16 03-23-2012 05:29 PM
1981 Gm 3.6 V6 Rough Idle And High Idle nomaddaddy Engine 1 11-15-2007 09:49 PM
Strange idle problem – part warm engine 78transam Engine 2 10-26-2007 05:16 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
High engine temp at idle. Bad Rat 414 Engine 13 05-17-2004 04:13 PM
