Quadrajet Idle Adjustment tool ? ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 06:46 PM
Theresa Shank's Avatar
Our streetrod had a 350 SBC with a Rochester Quadrajet carb. The idle circuit adjustment screws have the ends that look like the blade of a screw driver sticking out. I have seen a slick little tool that fits right in the proper spot to adjust. Doesn't anyone know if that tool is available at NAPA or any other location... As always..... THANKS.... THERESA
Old 05-29-2006, 06:48 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I got mine at WalMart, but they're available at NAPA, auto zone, advance... Pretty much anywhere that sells automotive tools.
Old 05-29-2006, 07:07 PM
poncho62's Avatar
Wiki Edits: 5
yeah, got one.............has a flexable shaft and a bunch of ends to fit different carbs.
Old 05-29-2006, 07:12 PM
Wal Mart has this tool ?? Where? With their other tools on the rack? THANKS.... THERESA
Old 05-29-2006, 07:49 PM
I made mine from a piece of steel brake line. Cheap and simple, but effective.
-Joe
Old 05-29-2006, 10:50 PM
curtis73's Avatar
Wiki Edits: 16
I just got it in the automotive section near the other tools. I think it was near the oil filter wrenches. Came with 6 bits for different carbs.
Old 05-30-2006, 01:46 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
I get mine at NAPA ..about $21.00 if I remember..
Before that I used rubber vacuum hose , smaller than the jet "body" sprayed with carb cleaner and quickly pushed over the jet screw..worked good most of the time.
Doc
Old 05-30-2006, 07:11 AM
Oops, my mistake...you were talking about the torx head idle speed adjustment screw...I used a piece of flattend brake line to adjust the mixture on the "sealed adjustment" carbs.
-Joe
Old 05-30-2006, 10:36 AM
Dave E Shank's Avatar
We found one at NAPA for $16.61. They said that type of head is called DOUBLE D. I hope it fits... THANKS... DAVE & THERESA
Adjustment tool for TPS screw sabino56 Engine 1 11-27-2005 06:11 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Idle adjustment - holley 650 dp 4777 Toyman Engine 5 07-30-2005 07:07 PM
? re: idle mix adjustment on 2150 2V carb cboy Engine 6 07-19-2005 05:31 PM
Setting Idle adjustment jrm123180 Engine 1 03-09-2004 01:57 PM
