Quadrajet Idle question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2005, 02:52 PM
How do i adjust idle speed on a factory quadrajet?
Old 05-20-2005, 02:59 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Turn the screw.
Old 05-20-2005, 03:01 PM
Thanks, i would have never guessed that it would be adjusted by a screw .
There is no screw that i see that contacts the linkage.
Old 05-20-2005, 03:18 PM
On mine, the screw is on the driver's side. It is partially hidden, keep looking.
Old 05-20-2005, 03:48 PM
Jmark's Avatar
If its a pre electronic Qjet, the idle speed screw is just inboard of the throttle linkage. Its a 5/16" hex/slotted screw mounted on the side of the carb. Head of the screw faces the front of the car.
If the carb has an idle solonoid, follow the engine decal on how to set the base idle and the activated idle speed.
Mark
Old 05-20-2005, 04:07 PM
Mark
Thank you. i will take a look to see if i can find it.
Old 05-20-2005, 04:12 PM
Jmark's Avatar
It may be hiding behind some brackets, but its there.
Fast Idle Issue ruiner808 Engine 3 01-20-2004 01:20 PM
new edelbrock won't idle... Trav Engine 1 11-29-2003 08:22 PM
Chevy 350 Won't Idle Down DavidMClary Engine 9 09-24-2003 11:31 AM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
