Quadrajet Idle Tube Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2010, 05:51 PM
KMyA
What's the secret to removing Q-jet idle tubes? I have new idle tubes drilled to .037" but can't get the old ones out. I haven't destroyed the carb yet!
Also where can I fnd a .037 drill? I have never seen one smaller than 1/16"?
BT
Old 05-14-2010, 06:30 PM
Take a punch which is the diameter of the idle tube, not the collar but the tube itself (.090?) and gently tap the tube down about 1/16". Take a drywall screw and cut the tip off it. Gently thread the screw into the collar with a screw driver until it "bites" on the brass collar. Take a micro torch and gently heat the casting for 30 seconds at the idle tube location. Using a pair of side cutters grab the screw at the base and gently pry up. This will pull the collar and tube right out of the casting.
Pin drills can be found on Ebay or at Harbor Freight.
Old 05-16-2010, 10:26 PM
KMyA
Thanks for the info. The tubes came right out.
bt
Old 05-17-2010, 05:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You want a "numbered" drill bit set. They go from #61 to #80 (smaller number = bigger diameter), cost ~ $10-$15 including the pin vise. 0.037" = #63 bit.
Numbered bits aren't meant to be used in a power tool, instead a "pin vise" is used to hold and turn the small bits by hand.
Help tuning 383 for street use strokey Engine 34 04-11-2008 05:51 PM
1967 pontiac 455 overheating brisk Engine 12 04-03-2008 10:17 PM
Too much camshaft!? pi71 Engine 28 04-10-2007 01:18 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Draft Tube removal garretthes Engine 3 11-02-2004 06:49 AM
