quadrajet problems......jets. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2013, 01:02 PM
severed head's Avatar
im having trouble passing smog. timing, idle speed, and mixture are near perfect. after getting it diagnosed, tech said the jets are possibly too big and im running too rich, 13.5-13.9. how do I know what size jets I have and witch ones to get.
oh yeah, by the way, the idiot before me ground off the numbers on the carb so im kinda screwed.
it is a 4bbl QJ on a 307 sbc.
thanks,
Cpl. Boyd U.S.M.C.
Old 09-30-2013, 03:01 PM
techinspector1's Avatar
Wiki Edits: 326
thanks,
Cpl. Boyd U.S.M.C.
Thanks for your service Corporal.
What would I do? I'd box it up and send it to Cliff Ruggles to be rebuilt.
Cliffs High Performance Quadrajets :: Qjet Carburetor Rebuild Kits, Parts, Quadrajet Rebuilding, Quadrajet Parts, Bushing Kits, Carb Tuning
Old 09-30-2013, 03:04 PM
thank you.
do you know off hand how much??
Old 09-30-2013, 03:22 PM
Wiki Edits: 326
thank you.
I don't know, it depends on the work he will have to do to bring it back to operational condition. Call him up......740-397-2921
Old 09-30-2013, 04:50 PM
RWENUTS's Avatar
Cliff's presently on a backlog. Get in line!! Could be 6 months till he sees yours.
Your jets might be perfect. You're likely idling on the power circuit and have totally uncovered the transition slot.
What's your vac advance hooked to? Ported or manifold?
What's your initial timing?
The Following User Says Thank You to RWENUTS For This Useful Post:
techinspector1 (10-01-2013)
Old 09-30-2013, 05:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Last time I spoke to him there was a ~6 month wait and the cost for a complete rebuild (not refinishing the zinc chromate or replating the hardware- just the internals) was around $200. Worth it if you're not able to do it yourself.
The thing you need to determine if you want to try rejetting it yourself, is whether your Q-jet has the large air bleeds like used on some Chevy carbs, or if the bleeds are smaller. If you don't know what jets and metering rods are in it now, you need to pull the top off the carb to see. Once you have the rod/jet sizes, you can inspect the carb to see what the bleeds are and we can go from there.
If the carb has an adjustable part throttle setup, you need to be sure it's tuned correctly, else that can hurt emissions. So can the wrong power piston spring- it works the same as a Holley power valve and if the spring is too strong, it'll be too rich under any load and possibly even at idle, although the a/f ratio you cite would seem to eliminate that as a possibility.
To try to narrow it down some, which carb does it most resemble from the two below? The pdf is by a guy, "Lars" who has compiled quite a bit of info on stock jetting, etc.
Name:	1974 Cad, 7044530 tunnel, small air bleeds, old casting, side inlet, divorced, front av po, hook.jpg
ID:	85482   Click image for larger version
Name:	BUICK V6 17080244 1980 4.1L 252cid throttle arm side view.jpg
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 09-30-2013, 05:30 PM
LATECH's Avatar
Why dont you post your test results as they will supply us with the info we need to help straighten out your car.
I assume you failed the 25/25 test? Which gas caused the fail? NOX CO HC CO2 ???
knowing which one can narrow down the area of concern.
Dont do anything until you know which direction to go.
Excess hydrocarbons can be caused by worn rings or a number of things.
Excess NOX can be caused by too high compression and no EGR action (if equipt)
Check the numbers first, that will give an indication of which direction to go.
I would be glad to help anyway I can....Thanks for your service to our great country.
Fact is stranger than Fiction
The Following 2 Users Say Thank You to LATECH For This Useful Post:
severed head (11-14-2013), techinspector1 (10-01-2013)
Old 09-30-2013, 05:40 PM
LATECH's Avatar
Post a couple picture of the carb as well. It should be pretty easy to ID.
Jets wont have anything to do with Idle. Idle channel restrictions and Idle air bleeds will be the trouble if it fails at idle.
At cruise (25/25) it is on the main circuit (jets) and metering rods, APT as Cobalt mentioned and power piston spring could be coming into play.
Dont rule out other mechanical problems. Weak rings, carbon build up in the cylinders....
The Following User Says Thank You to LATECH For This Useful Post:
Old 09-30-2013, 06:24 PM
LATECH's Avatar
This may help a little
Carburetors: Recarbco - rebuilt carbs and carburetor troubleshooting
Old 10-01-2013, 11:09 AM
spinn's Avatar
Try to rebuild it yourself. If you have some mechanical skill or interest in the hobby, you will benefit from understanding how to use the carburetor. Buy cliffs' book. I rebuilt my Qjet with his advice. In book examples, it used the same performer cam I installed. His best formula was spot on. The vacuum pods need to be timed right, and the ATP system understood. The book will explain the systems of the Qjet.
You can tune it pretty well with a old O2 sensor and DVOM. Dial it in as well as anybody.
I would try.
The Following User Says Thank You to spinn For This Useful Post:
Old 10-01-2013, 04:28 PM
LATECH's Avatar
Originally Posted by Denny View Post
First of all, I would look up the carb number. Q-jets were mounted on many engine types. Each type of Q-jet, has a particular set of jets and rods to start out with, according to the engine they are sitting on. And lets not forget to check that throttle shaft for play. A vacuum leak there will through things off as well.
He stated that the numbers have been ground off...also a quadrajet never came on a 307 as a stock piece.
That is why I asked him to post a pic, at least we can narrow it down and probably figure it out after the jet numbers are exposed.
Old 11-14-2013, 05:08 PM
https://www.facebook.com/photo.php?f...size=960%2C720
here is the picture of the carb. I hope it helps.
the only gas that was high is CO. I believe it indicates a rich condition. it passed the idle gasses but failed the 15\25 with high co. i'd have to grab the paperwork and see what the exact measurement was, but I believe passing CO was 2.?? and I failed at 3.?? any ideas? if you need more info or pictures. let me know
Old 11-14-2013, 05:37 PM
LATECH's Avatar
Hi CO is a rich condition. Seeing that it passed at Idle and not at part throttle acceleration, I would have to say the guy at the testing station was probably correct.It needs jetted down.You could put a lighter spring under the power piston , this may help keep the metering rods in the jets farther, leaning it out some at part throttle acceleration (15/25)
Idont suspect the float level or a soggy saturated float as it passed at idle.Problem is in acceleration enrichment (metering rods-jets power piston)
Old 11-14-2013, 07:39 PM
Thanks Denny,
I looked at the site and I believe I have a blue one. But its only rated up to 12 Hg. And mine is pulling 16-18 Hg.
Old 11-14-2013, 08:07 PM
RWENUTS's Avatar
While you're checking the power piston spring, check to see how rich your apt is set at. I've seen some that are 9 turns from bottom. Way rich in the mid range. Look here about 3/4 way down the page.
http://www.crankshaftcoalition.com/w...#Trouble_spots
Quadrajet choke problems Siggy_Freud Engine 13 01-17-2012 11:54 PM
Quadrajet Idle Problems 69chevyLWB Engine 20 10-25-2011 08:15 AM
Quadrajet Jet Problems dart1975 Hotrodding Basics 2 02-18-2011 07:56 AM
Edelbrock750 jets vs 600 carb jets KeithB123 Engine 1 01-11-2007 07:02 PM
High Altitude Q-Jets vs std Q-Jets DHMag Engine 3 01-09-2006 07:16 PM
