Quadrajet Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2008, 10:22 PM
super_silent's Avatar
Quadrajet Question
Hello everyone,
I have a 67 chevelle with a 327/275 hp, I just bought the car and when I'm driving and push the accelerator all the way the floor the car starts to hesitate and stumble once the secondaries open up, it almost feels like it's starving for fuel. I let off and it goes back to normal. I have another rebuilt Q-jet in a box , (I tried it once on my camaro but it had a stumble when accelerating from a stop) I and I put that on the car and it seemed to correct the hesitation at higher rpm's but it stumbled off the line. anyone have any ideas what may be causing this and how I might correct it ??
Thanks in advance
Old 05-26-2008, 10:53 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
The Chevelle carb might have dirty metering rods/jets in the secondaries.
That's if you did all the normal tune-up stuff plus timing, etc.
The rebuilt carb on the Camaro sounds like the accelerator pump or nozzles are not working.
Old 05-26-2008, 10:56 PM
the car has new Bosch plugs, new wires, timing is set at 14 degrees.
Old 05-26-2008, 11:19 PM
Last journal entry: more sheet metal stuff
Sounds like your secondary air valve is opening to fast. there is an adjustment for it located on the passenger side of the carb where the linkage connects to the secondary air valve. kinda hard to describe without showing you
Old 05-26-2008, 11:22 PM
I thought that as well and tried checking if they were too loose but they don't appear to be.
Old 05-27-2008, 04:49 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
There is a little spring that slows the opening of the secondary air doors. Over time it weakens. On the passenger side there should be an allen screw and a flathead set screw. Adjust that spring a turn or two tighter and I almost guarantee you problem will dissapear.
Old 05-27-2008, 09:11 AM
Jmark's Avatar
Here is the allen screw and adjusting (slotted) screw that Curtis mentions. Personally, I like to make very very small changes in the spring tension, maybe 1/8th turn at a time. If it ends up too tight, not only will it open way too late, if at all, but will act like a closed choke and cause it to go way rich.
Mark
Old 05-27-2008, 09:31 AM
Thanks very much to everyone for all the input, I will make the adjustment later this afternoon and post results.
Old 05-27-2008, 09:36 AM
malc's Avatar
Living At The Speed Of Life
Here it is in words at
thirdgen.org.Itīs the same for regular and computer controlled carbs.
Old 05-27-2008, 09:08 PM
Problem solved. I swapped out the metering rods with the other Qjet I have here and re-adjusted the secondary air doors....no more bogging ! Thanks again to everyone for all the great info.
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
Quadrajet question Speakrdude Engine 10 10-25-2009 02:16 PM
Quadrajet rebuild question? Shefron Engine 14 11-14-2005 12:01 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
