Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quadrajet Question
Old 01-14-2013, 11:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by DoubleVision View Post
Thanks Cobalt. So I need to snatch the carb and figure out a way to close them up or should I just plug them entirely?
IIRC, my Q-jet originally from a 4.3L V6 (17086047) has no bypass orifices. So I would say to block them off entirely, then you can add bypass air only if it's needed. If your cam requires a lot of initial timing you might need some bypass air to keep from opening the primary butterflies too far. The bypass air is similar to drilling holes in the primaries.
The Following User Says Thank You to cobalt327 For This Useful Post:
DoubleVision (01-14-2013)
