quadrajet runnin rich - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2010, 06:29 AM
I got a 78 chevy crate engine,with stock quadrajet intake,modified cam,and the carb is off 77 olds.. I rebuilt the carb with new gaskets,float,float needle/seat,not shure what the original jets/metering rods were but i am runnin 51 rods,and 72 jets. the mixture screws dont do much for adjustment, one time it will sit there and idle fine and run rather good,and the next time it dont wanna idle for jack,and sometimes it is low or other time it is high. when i floor it from idle i get a puff of black smoke wich indicates it is rich.no matter how far in i turn the screws it dotn stop that puff of black smoke. i do have a vaccume leak wich i need to fine,but that would lean it out more so dont make sence why i got the black smoke when i floor it from idle.. also have the metering rod stop set at 2 turns out should i turn it in more? also the float is adjusted at 17 32'ds wich it idled at that setting one time and the other it didnt so i dotn think that the float level is the problem. well i cleaned the plugs it will idle now fair for about 20 sec sometimes longer then dies power piston is all the way down like it should when runnin but less black smoke now
Old 06-05-2010, 07:13 AM
A vacuum leak can cause low vacuum at idle which will prevent the power piston from seating. Fix the vacuum issue before you attempt any tuning on the carb. Most of what I have read says to set float level at 1/4".
Old 06-05-2010, 12:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The float level is too high at 17/32". That's over 1/2", the "normal" setting for a Q-jet is closer to 1/4", give or take. Your carb might be better at 7/16"- 15/32".
When using the "M" series rods, .075-.076" range jets will be a better choice for you, IMO.
The jetting as it now is, will probably be lean at WOT/low vacuum, high load conditions, it may be OK at cruise, moderate throttle.
The APT should be about 3 turns. Idle mixture screws should be about 1-1/2 to 2 turns out.
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 09:19 PM
quadrajet too rich? murrsue Engine 10 02-09-2007 06:18 AM
BG/BC Rich Idle & Idle Air Bleeds/IFR 68NovaSS Engine 3 11-10-2006 11:36 PM
Correction 1-7 & 4-6 rich, Holley solidaxel Engine 11 09-29-2005 09:14 AM
Would you guess it's runnin rich or lean stonedchihuahua Engine 16 07-08-2003 07:06 PM
