Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quadrajet on stock 350 idles fine drives like junk
Old 08-02-2012, 02:27 AM
teledrew teledrew is offline
Nothing worse...
Originally Posted by DQ81 View Post
these were my initial thoughts.
fuel pump has been replaced in the past six months according to the previous owner. It does have that 'new pump' look, haha.
It does have an inline filter and I'm off to check the filter at the inlet.
I was thinking either filters or float level, feul starvation, because of it's behaviour.
Thanks for your help!
I'll let you know, nothing worse than a thread without an end.
I have the same symptoms and have done same as you to try and solve. Did you ever find a solution, you left the thread without an end!
