Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quadrajet on stock 350 idles fine drives like junk
Old 08-02-2012, 09:04 AM
DQ81 DQ81 is offline
Originally Posted by teledrew View Post
I have the same symptoms and have done same as you to try and solve. Did you ever find a solution, you left the thread without an end!
The carb needed a full rebuild.
hope that helps.
