your carb size is ????
with your 350 u should be 600cfm or a little bigger won't hurt. i never did like a quad.. i'm using a edelbrock and love it.. if your doing alot of off roading u may want to looking holley's truck carb...
Often carb problems, aren't carb problems.
What you might try, is see where the timing is at to start with. Initial, total and how the vac adv is hooked up- whether to ported or manifold vac. Once that is straightened out, set the idle mixture screws w/a vac gage if possible, otherwise to the best idle speed w/both needles about (within 1/2 turn at the most) the same distance out. Not until this is done, can any real attempt at tuning the carb can be done, although a lucky guess might pick out the problem from the possibilities. Like float level, fuel pump, vac leaks, warped castings, incorrect power piston spring, jetting rods, secondary air valve setting etc. If you just want to try something EZ- take a can of carb cleaner to it, following the can directions. It may loosen/clean the air bleeds and orifices enough to straighten it out. Tighten (but don't OVER tighten the carb bolts. The 2 front bolts go all the way through the carb so be careful. Check that the screws securing the airhorn (and throttle body- but you need to pull the carb) for tightness. Make sure the float is ABSOLUTELY not closing on you while the engine's running. Let us know. |
thanks, all good calls.
Heading out the door now with the timing light and going to check the vacuum canister etc. how do i check the float on one of these carbs? i'm very unfamiliar with them. tia |
New
To check the float your going to have to do a visual inspection. Considering the headaches your having, after confirming ignition is proper, Get a rebuild kit. for the carb. Find a large table, & an old white bed cover, Start your rebuild process. I have had this problem before. I cant answer what the actual problem was because sometimes its easier to just overhaul the system. As for accel. problems on inclines, these OEM carbs suck. You'll need to go to holley & by a truck kit. Otherwise a built 1406 or 1407 has always been my fav. Hope it helps.
Timing is fine, vac advance works fine.
8 BTDC, all in around 2.8k RPM @ 36 degrees. This makes sense as like I said earlier: If the truck idels a few minutes, punch it and accelerate moderately or WOT it's just fine for about 7 seconds and then stumbles almost completely stalls, let off the gas it recovers but if gas is re-applied it surges and won't accelerate or hold a speed properly. The longer I stay off the gas the longer I can accelerate afterwards but it's back to surging pretty quickly. Timing isn't going to effect this. It's a factory mechanical quadrajet with the correct timing. What's next? |
The floats can over time get gas logged and heavier than normal. This causes the level to be too high. If the carb just began to misbehave, it might be a simple fix. If the carb is new to you or you don't know when it was last rebuilt, etc., it's a reasonable thing to expect to have to rebuild it. You will also want to replace the fuel filter located at the fuel inlet/filter housing (1" size wrench to remove it). Hold the 1" from turning while you turn the fuel line fitting off w/a 5/8" fitting wrench (if it still has the OEM steel fuel line)- then remove the filter housing. Be careful of the plastic gasket on the end of the housing- don't let it get between the threads when you reassemble it, and be careful not to overtighten or cross thread it. |
See my reply above re the filter. There might also be an inline filter that has been added at some point- it too will need checked/replaced if needed. The pump might be on its way out. |
these were my initial thoughts.
fuel pump has been replaced in the past six months according to the previous owner. It does have that 'new pump' look, haha. It does have an inline filter and I'm off to check the filter at the inlet. I was thinking either filters or float level, feul starvation, because of it's behaviour. Thanks for your help! I'll let you know, nothing worse than a thread without an end. |
You have gotten some good advice and I think you're on the right track. You should check/replace the filter first. Real common symptom. After that it almost sounds like your float plunger is sticking and not dropping, not letting the bowl fill with more fuel to keep up with demand, but that's just a WAG. Also, your rig is a 78 so your pickup in the gas tank could be clogged and sucking the strainer against the end of the pickup tube.
Nothing worse...
I have the same symptoms and have done same as you to try and solve. Did you ever find a solution, you left the thread without an end!
hope that helps. David |
| Stock 350 with 305 truck heads? | CrazyT | Engine | 3 | 08-04-2009 01:15 PM |
| Stock 1974 sbc 350 build | stoney 81ta | Engine | 7 | 06-21-2009 08:10 AM |
| stock 350 vortec in a camaro cam advice. | dany7018 | Engine | 6 | 05-12-2009 05:17 PM |
| Stock crate 350 (Cam Questions) | Savage64chevy | Engine | 3 | 01-21-2003 12:34 PM |
| 350 chevy: stock cam or 3 quarter cam ? | 65roln | Engine | 8 | 03-19-2002 11:18 AM |
