Quadrajet Throttle shaft seems to be binding - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2013, 06:35 PM
When I rebuilt my Quadrajet last year (its from an '86 GM truck) I put new bushings on the primary throttle shaft and lubricated it with lithium grease when I reassembled. Everything seemed to be moving okay until the weather got cold. Now when I let off the pedal slowly the throttle does not always come all the way back to the stop and it often sticks at about 1500-2000 RPM. If I let the throttle snap back quickly it will go all the way back to the stop. I already have the standard dual return spring setup on the Quadrajet.
Is there a better lubricant to use for the throttle shaft, and is it something I could spray in without pulling the throttle shaft out? Its not a simple job to pull out the throttle shaft to spray in the lubricant because I staked the screws that hold the plates on the shafts, but I could do that if I have to.
Thanks,
Bruce
Old 02-18-2013, 07:45 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
If you would have stayed here in San Antonio, you would not have that problem.
Can't say we have even had more than a day of winter here yet this year.
Think maybe the bushings are contracting just a bit in the cold???
Just a thought----it's nap time for me
Old 02-19-2013, 11:04 AM
vinniekq2's Avatar
Have you tried water displacement 40 to see if it is a lubrication issue?
Old 02-19-2013, 03:11 PM
You might want to look and see if any of the throttle plate are binding. I don't know how far you tore your carburetor down but if you removed the plates it's a place to look.
BB
Old 02-19-2013, 07:46 PM
Bryan59EC - Weather is considerably colder here than in SA, and its definitely meant that I needed to do some retuning on the truck to make it run better when its cold.
boothboy - I had hoped to get the throttle shaft to loosen up without pulling the carb off, but you are right about checking the throttle plates. I remember when I reassembled everything that the tolerances are very close and it wouldn't take much to make it bind.
Thanks,
Bruce
64 Chevy Impala throttle cable for quadrajet 64r1 Hotrodding Basics 10 02-22-2013 02:54 PM
screws snapped off in the secondary throttle shaft of my rochester quadrajet - HELP! JMSTOY Hotrodding Basics 3 03-24-2012 03:09 PM
More Quadrajet Stuff-- Question about polished throttle plate clicketyclack Engine 6 07-17-2010 05:23 AM
Quadrajet throttle bracket... rbomar Engine 2 08-30-2007 08:41 AM
Identifying Quadrajet Ports on throttle body... flipp121 Engine 11 05-19-2005 09:27 PM
