Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quadrajet Tuning
Old 09-06-2011, 07:38 PM
lt1silverhawk's Avatar
lt1silverhawk lt1silverhawk is offline
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Hey Tommy,
Originally Posted by TommyK
Check for vacuum leaks. If none found the next culprit would be an excessively lean idle setting.
Thanks! It was a lean condition. I tightened up the two mixture screws, and then turned them out 5 turns, counter-clockwise. The engine was still a bit shaky, so I did one more full turn on each one, and that did the trick.
The engine now starts up at 1500 rpm (vs 1000 rpm), and drops to a smooth 750 rpm (vs barely 500 rpm).
The transmission no longer shifts with a super-loud clunk. (It still clunks a bit, but it has always done that since I bought it a year and a half ago.) Thanks again!
