Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quadrajet Tuning
Old 09-07-2011, 03:54 AM
TommyK TommyK is offline
Originally Posted by lt1silverhawk
Hey Tommy,
Thanks! It was a lean condition. I tightened up the two mixture screws, and then turned them out 5 turns, counter-clockwise. The engine was still a bit shaky, so I did one more full turn on each one, and that did the trick.
The engine now starts up at 1500 rpm (vs 1000 rpm), and drops to a smooth 750 rpm (vs barely 500 rpm).
The transmission no longer shifts with a super-loud clunk. (It still clunks a bit, but it has always done that since I bought it a year and a half ago.) Thanks again!
Glad I could help. One final note. If you have the late model fine pitch metric idle screws then 5 turns out is a fairly normal idle setting. If you have the earlier coarser pitch screws and the screws feel wobbly and unstable being five turns out then you may want to consider enlarging the idle screw orifice to obtain a more normal setting of 2-3 turns out.
