Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quadrajet tuning '67-'69 Firebird Sprint
Old 10-25-2012, 03:30 PM
Nortonfan Nortonfan is offline
Originally Posted by 75gmck25 View Post
I used the Ruggles book and one of his high end rebuild kits (includes more parts) to rebuild a post-76 Quadrajet. The only issue I found was that his book covers so much material on both standard rebuild and performance additions that I was doing a lot of flipping back and forth in the book. I wanted to get a fairly stock carburetor, but also address some performance changes as part of the rebuild.
For example, I removed and tapped the plug for the APT screw so that I could adjust it after I put the carb together. However, it ran well with the stock setting, so I left it that way.
I found the carburetor on an '86 Chevy truck, since they used the non-electronic, non-electric carbs longer on the trucks than on the cars.
Thanks for these tips, Bruce. I will keep in mind not to alter the stock configuration of the carburetor until I am absolutely certain that whatever changes I do make are necessary and will be an improvement... though something tells me I will be pulling the carb's cover a few times before I'm finished with the adaptation. Things are looking quite promising, indeed!
Norman C
