Quality of Bondo - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-24-2006, 03:31 PM
Wiki Edits: 31
yep, some carquest have paint dept, and they sell PPG. I was going to get my paint from a somewhat local 1, in Oneonta Ny, gave them a color swatch to match with there color matching camera, looked at it, said it was too small and pointed to the books. I left. then I went to a " Real " PPG dealer and they matched it perfectly with the same equipment, for less than I would have paid at the carquest
  #17 (permalink)
Old 10-24-2006, 04:22 PM
Went to the paint supplier and got Evercoat Glaze. The Rage is $35/gal and gold is $45/gal. I will look at carquest next time. Don't have too many in AZ. What is max thickness of filler that should be used?
So, just how important is using quality sandpaper? MARTINSR Body - Exterior 42 08-23-2006 08:32 PM
Which bondo should I use? Nightfire Body - Exterior 8 07-26-2004 05:38 PM
Bondo vs Dynatron ChrisMiddleron Body - Exterior 10 08-29-2003 04:07 AM
How long does it take thin amounts of bondo to crack? stonedchihuahua Body - Exterior 14 07-12-2003 08:02 PM
bondo removal question broncoman Body - Exterior 3 06-22-2003 01:16 AM
