Those of you who have used wheel adapters either as a spacer or a lug conversion I have noticed 2 main things. For one studs tend to break on most adapters. For two most don't have a centering ring.
I am looking for 4x114.3 to 5x4.5 adapters that will hold to high stress levels, ie autocross, road racing, and drag.
Does anyone have suggestions or thoughts? For future reference I have literally called everywhere(and googled for hours on end) and custom wheels in the 17" range are out of the question, hence the adapters.
How about having your Drums/Discs redrilled for the proper bolt hole spacing that you want?
I have used Wheel Spacers years ago, and I could never keep them tight, and I was always wondering when the Studs would break-IMHO, they are nothing but a bad band-aid-
Moser will redrill hubs and rotors, $30 per set, so $120 for the whole car.
On the wheel adapters, I machine a press in ring that will fit the hub pilot, and center the wheel. I have a pair on my car, in the rear, that have been on there for 18 years, about 50,000 miles with no issues.
Are they not in portland? I am in Minnesota if i could find a local company that will do that that would be perfect. I am currently at zero offset, I think I will have a stronger chance finding rims as wide as I need with zero offset or close.
Its for one of my old s30 z cars I have 2 1978 datsun 280Zs. I have searched for wheels for a long time can't seem to find anything that I want.
Rota has the size that i want but they are a year and a half out - i've called around. The size they run are 17x9 with -13 in front, 17x9.5 with -19 in the rear. That sounds about perfect. I was planning on running a set of bmw (5x120) or mustang wheels (5x4.5) whatever ended up working, i really don't care about looks as long as I could fit a 245/45r17, I have a deal with bridgestone to run re11s on my cars.
i just got a quote from stockton in california. 41 for shipping each wheel. 209 per wheel bare (no coating) 17x9 they said they are willing to drill out the holes and and make them a 4x4.5 wheel.
They don't go up to the 9.5 that i would want but i think i can live with 9 inches.
Also they said they should be about 35 pounds each wheel, which in reality isn't really all that bad.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
