-   -   Quality Wheel Adapters (rims) (http://www.hotrodders.com/forum/quality-wheel-adapters-rims-215812.html)
blight 03-01-2012 01:02 PM
Those of you who have used wheel adapters either as a spacer or a lug conversion I have noticed 2 main things. For one studs tend to break on most adapters. For two most don't have a centering ring.
I am looking for 4x114.3 to 5x4.5 adapters that will hold to high stress levels, ie autocross, road racing, and drag.
Does anyone have suggestions or thoughts? For future reference I have literally called everywhere(and googled for hours on end) and custom wheels in the 17" range are out of the question, hence the adapters.
35WINDOW 03-01-2012 03:20 PM
How about having your Drums/Discs redrilled for the proper bolt hole spacing that you want?
I have used Wheel Spacers years ago, and I could never keep them tight, and I was always wondering when the Studs would break-IMHO, they are nothing but a bad band-aid-
John Se 03-01-2012 03:47 PM
try this guy, Fred Goeske
http://www.wheeladapter.com/
call him up and explain your situation, you want a Hub-centric adapter.
Oops I just noticed that he doesnt do 4 to 5 lug, some others do though, look on ebay
blight 03-01-2012 04:04 PM
ebay stuff is junk thus far- still googling
blight 03-01-2012 05:14 PM
i would also need the hubs done.
enjenjo 03-01-2012 07:38 PM
Moser will redrill hubs and rotors, $30 per set, so $120 for the whole car.
On the wheel adapters, I machine a press in ring that will fit the hub pilot, and center the wheel. I have a pair on my car, in the rear, that have been on there for 18 years, about 50,000 miles with no issues.
blight 03-01-2012 07:54 PM
Are they not in portland? I am in Minnesota if i could find a local company that will do that that would be perfect. I am currently at zero offset, I think I will have a stronger chance finding rims as wide as I need with zero offset or close.
matts37chev 03-01-2012 08:25 PM
what vehicle is this going on and what size/kind of wheel are you trying to put on it?
you did say autocross use correct?
there might be a better solution than spacers
blight 03-01-2012 08:35 PM
Its for one of my old s30 z cars I have 2 1978 datsun 280Zs. I have searched for wheels for a long time can't seem to find anything that I want.
Rota has the size that i want but they are a year and a half out - i've called around. The size they run are 17x9 with -13 in front, 17x9.5 with -19 in the rear. That sounds about perfect. I was planning on running a set of bmw (5x120) or mustang wheels (5x4.5) whatever ended up working, i really don't care about looks as long as I could fit a 245/45r17, I have a deal with bridgestone to run re11s on my cars.
blight 03-01-2012 09:47 PM
I also (btw) do not want to do any kind of brake conversion for too many reasons to list.
joe_padavano 03-02-2012 04:43 AM
X2 on Fred Goeske. Former rocket funny car driver, great guy, quality product. I've had his spacers on my dually for years now.
blight 03-02-2012 06:09 AM
i called him and he refused to do a 4 to 5 lug, he even hung up on me
blight 03-02-2012 06:48 AM
Diamond racing wheels just refused me to make 17x9 and 17x 9.5 racing wheels - said they were too big and heavy and no longer makes them in that size.
matts37chev 03-02-2012 08:18 AM
its hard to find anything wider than 7.5" in a 17" - 4 on 4.5
blight 03-02-2012 04:33 PM
i just got a quote from stockton in california. 41 for shipping each wheel. 209 per wheel bare (no coating) 17x9 they said they are willing to drill out the holes and and make them a 4x4.5 wheel.
They don't go up to the 9.5 that i would want but i think i can live with 9 inches.
Also they said they should be about 35 pounds each wheel, which in reality isn't really all that bad.
