Quality Wheel Adapters (rims) - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2012, 02:02 PM
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
Those of you who have used wheel adapters either as a spacer or a lug conversion I have noticed 2 main things. For one studs tend to break on most adapters. For two most don't have a centering ring.
I am looking for 4x114.3 to 5x4.5 adapters that will hold to high stress levels, ie autocross, road racing, and drag.
Does anyone have suggestions or thoughts? For future reference I have literally called everywhere(and googled for hours on end) and custom wheels in the 17" range are out of the question, hence the adapters.
Old 03-01-2012, 04:20 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
How about having your Drums/Discs redrilled for the proper bolt hole spacing that you want?
I have used Wheel Spacers years ago, and I could never keep them tight, and I was always wondering when the Studs would break-IMHO, they are nothing but a bad band-aid-
Old 03-01-2012, 04:47 PM
try this guy, Fred Goeske
http://www.wheeladapter.com/
call him up and explain your situation, you want a Hub-centric adapter.
Oops I just noticed that he doesnt do 4 to 5 lug, some others do though, look on ebay
Old 03-01-2012, 05:04 PM
ebay stuff is junk thus far- still googling
Old 03-01-2012, 06:14 PM
i would also need the hubs done.
Old 03-01-2012, 08:38 PM
Moser will redrill hubs and rotors, $30 per set, so $120 for the whole car.
On the wheel adapters, I machine a press in ring that will fit the hub pilot, and center the wheel. I have a pair on my car, in the rear, that have been on there for 18 years, about 50,000 miles with no issues.
Old 03-01-2012, 08:54 PM
Are they not in portland? I am in Minnesota if i could find a local company that will do that that would be perfect. I am currently at zero offset, I think I will have a stronger chance finding rims as wide as I need with zero offset or close.
Old 03-01-2012, 09:25 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
what vehicle is this going on and what size/kind of wheel are you trying to put on it?
you did say autocross use correct?
there might be a better solution than spacers
Old 03-01-2012, 09:35 PM
Its for one of my old s30 z cars I have 2 1978 datsun 280Zs. I have searched for wheels for a long time can't seem to find anything that I want.
Rota has the size that i want but they are a year and a half out - i've called around. The size they run are 17x9 with -13 in front, 17x9.5 with -19 in the rear. That sounds about perfect. I was planning on running a set of bmw (5x120) or mustang wheels (5x4.5) whatever ended up working, i really don't care about looks as long as I could fit a 245/45r17, I have a deal with bridgestone to run re11s on my cars.
Old 03-01-2012, 10:47 PM
I also (btw) do not want to do any kind of brake conversion for too many reasons to list.
Old 03-02-2012, 05:43 AM
X2 on Fred Goeske. Former rocket funny car driver, great guy, quality product. I've had his spacers on my dually for years now.
Old 03-02-2012, 07:09 AM
i called him and he refused to do a 4 to 5 lug, he even hung up on me
Old 03-02-2012, 07:48 AM
Diamond racing wheels just refused me to make 17x9 and 17x 9.5 racing wheels - said they were too big and heavy and no longer makes them in that size.
Old 03-02-2012, 09:18 AM
& matts38chev
its hard to find anything wider than 7.5" in a 17" - 4 on 4.5
Old 03-02-2012, 05:33 PM
i just got a quote from stockton in california. 41 for shipping each wheel. 209 per wheel bare (no coating) 17x9 they said they are willing to drill out the holes and and make them a 4x4.5 wheel.
They don't go up to the 9.5 that i would want but i think i can live with 9 inches.
Also they said they should be about 35 pounds each wheel, which in reality isn't really all that bad.
wheel adapters alkey Suspension - Brakes - Steering 6 12-12-2011 05:18 PM
wheel adapters j-stylez General Rodding Tech 2 03-27-2008 07:00 PM
wheel adapters ikeaguirre14 General Rodding Tech 5 10-03-2004 10:13 PM
wheel adapters ikeaguirre14 Introduce Yourself 1 09-28-2004 11:45 AM
wheel adapters??????? olsixrod Suspension - Brakes - Steering 0 04-20-2004 08:03 PM
