Quardajet Lag at the light - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2010, 10:33 AM
Hi guys,
Hopefully a basic question that will be easy to resolve. I just rebuilt my q jet and while it idles better and is more responsive, there is still a lag when at the light and I go to full throttle. When coasting along and I go full throttle the secondaries are loud and the truck will move, so I am assuming this an adjustment that is easy to resolve?
This is on a late 70's 350 with HEI and a 17058213 Q jet. I reset the idle mixture screws to 1 3/4 as they were before, have not touched the idle speed nor timing.
I was thinking start with the carb and get it best as possible but not sure where to start. Advice?
Old 07-18-2010, 11:13 AM
DoubleVision's Avatar
You will need to adjust the secondary upper throttle flaps. They are controlled by a tension spring. This will show you how it`s done:
http://www.73-87.com/7387garage/drivetrain/myqjet.htm
Old 07-18-2010, 06:49 PM
sounds like you need more accelerator pump.
get a performance accelerator pump rod from summit racing or cut about 1/4" off the stock rod end.
set the idle air mixture to the highest vacuum which is typically the highest rpm with a set idle screw position.
Old 07-19-2010, 04:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 57vroom
Hi guys,
If you have a vacuum gage, use it to adjust the idle mixture screws to give the highest vacuum at idle, w/the screws turned out about the same amount. Gently rev the engine between adjustments and allow the engine to come back to idle, then note the reading. If you don't have a vacuum gage, use an accurate tach and go for the highest RPM at idle.
If you don't have the vacuum advance hooked up to a manifold vacuum source, you should give it a try.
When you use manifold vacuum for the advance (if not done already) the idle speed and vacuum reading will increase. Use the curb idle screw to lower the idle back down.
You should use about 36 total timing (not including vacuum advance), all in by around 2500-3000 RPM, depending on weight, gears, fuel, etc. This is adjusted by the springs atop the mechanical advance mechanism under the rotor.
After doing the above, see if the bog has been cured or lessened.
If not, either the accelerator pump shot, the secondary air valve- or both- may need attention.
You should see a stream of fuel come from the accelerator pump discharge ports as soon as the throttle is opened. There are two holes to choose from on the accelerator pump arm. The innermost hole gives a larger shot.
Old 07-20-2010, 08:02 PM
Thanks for the quick responses, you guys are great! This might be a baisc question as it related to the timing, but how do I get that many degrees? The extent of my experience here was on the old point style distributor where you just turn the cap to get a value of X. Is HEI different? Sure hoping my 1973 timing light/ analyzer is going to suffice on this endeavor....
Old 07-21-2010, 09:03 AM
yes, just turn the distributor to get the timing you need (hei or points style).
however, you will need timing tape on the balancer or use a timing light with a degree knob to see the total timing number on the balancer.
Old 07-21-2010, 09:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you don't have a degreed damper or a dial back timing light, you can easily make a temporary TIMING TAPE.
To set the total timing, disconnect the vacuum advance and plug the line from the vacuum source. Then, increase the RPM until you see no more timing advance- this timing reading is the total timing.
If it is less than 36-38, turn the distributor body CCW until you see the correct reading.
Return to an idle and see what the initial timing is. You'd like there to be at least 10-12 if the engine is stock. Another thing you can do is to connect the vacuum advance to a manifold vacuum source. If it is now on a ported vacuum source, this will cause the idle speed to increase. Just readjust the curb idle screw to give the correct idle speed and see how it drives like this.
Old 07-21-2010, 10:08 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
cobalt327 . Even though my T-bucket runs like a scalded dog on take-off , I am going to do what you mention here just because I have the time .(read retired) BTW . I wish I had a Q-jet on my T-bucket just 'cause I love the HUGE secondaries . But it runs great with the 1405 Edelbrock so I guess I'll keep my money .
Old 07-21-2010, 10:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You know what they say about fixing things that ain't broke... lol
But seriously, the closer to stock the cam is, the less the whole ported vs. manifold vacuum for the vacuum advance matters, IMO. I'd only suggest it IF the engine wasn't responding well to "normal" tuning procedures.
GEN Light On with IGN Key OFF strausbo Electrical 10 09-06-2009 06:59 PM
oil warning light romaro Engine 3 09-15-2006 09:31 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 12:12 PM
a little humor to get through the evening antirice Hotrodders' Lounge 7 08-28-2003 08:36 AM
