Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quarter Panel Patching Questions
Old 02-19-2012, 08:46 PM
John68040's Avatar
John68040 John68040 is offline
Originally Posted by deadbodyman
ON A 77 PINTO ?????
seriously ,if it were me I'd separate the inner and outer skin put them in the cabinet blaster then epoxy them, screw the outer piece on where its supposed to be then the inner,take the outer skin back off and weld the inner then weld the outer
Nope, on an '80. Daily driver when there's no salt on the roads. 76 motor though I found out, haha.
Separating the skins isn't a bad idea. I could weld the outer and have access to it from the back to get it nice and smooth. I'll have to take a close look and see if I can separate them on the seam easily enough. I'd like to avoid screws because that's more welding later on to fill the holes.
I was thinking about making a simple magnetic stand like one of those scissor-type lamps to hold it in place, or just have someone hold it while I do a few quick tacks.
