Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quarter Panel Patching Questions
Old 02-19-2012, 09:56 PM
John68040's Avatar
John68040 John68040 is offline
Originally Posted by deadbodyman
The nice thing about using drill screws is once you put it all together and everything fits just right you can unscrew the outer skin and have ez access to the inner for welding then just screw the outer back on exactly where it was using the same holes and weld that,,, you'll have to drill the spot welds to get it apart ...
You're talking about doing an overlap though, right? I wanted to butt weld it, so there'd be nothing to screw to unless I added a piece to hold it together temporarily.
