To replace the full quarter is a major task and not for the novice. For what it will cost in parts materials and time ,you would be better off letting a good body shop do it.Some pics would help but if its just bent you could get by just fixing what you have.If it's creased or torn you can get just a patch panel that is not that difficult to install.Did it damage the inner panel?
I'd replace it,most definetly
1/4 panel replacement
Just to be sure you know, it's better to cut a quarter off a good donor car. The new repo quarters need a lot of work fit right. I just replaced both quarters on my GTO and they look good but I had to improvise in some areas to get a good fit. Any Pontiac guy can see that some of the seams aren't quite right. Also you'll need to do some blocking and sanding to get them straight once welded in.
regards Ron |
| where to cut quarter panel? | freethinker52 | Body - Exterior | 25 | 10-11-2010 04:11 AM |
| Quarter panel help | 930dreamer | Body - Exterior | 2 | 03-27-2009 06:20 AM |
| Import quarter panel repair | hoffmandirt | Body - Exterior | 14 | 06-24-2008 05:22 AM |
| quarter panel. | shadowismydogsname | Body - Exterior | 2 | 04-26-2008 04:52 PM |
| Quarter Panel Patch | Ron M | Body - Exterior | 1 | 07-27-2004 01:12 AM |
