Quarter panel to rocker. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2011, 06:34 PM
The bottom of my quarter panel sits on top of the rocker panel and is attached inside under the window assembly with spot welds. How did they do this and is it feasable to weld up the new quarter to the rocker on the outside thereby eliminating the seam (as seen from outside) from the back of the door to the front of the wheel opening. I can reach thru and plug weld a few spots on the inside also. This is a 1970 Skylark A-body.
Clint
Old 03-08-2011, 06:57 PM
I just finished putting rear quartera on a 68 A body and they are basicly the same.If you can get in there and tack it in a couple of spots thats all you need in that area.I wouldn't weld them on the outside on the seam.I see quite a few that has been done that way and it just doesn't look good.
Old 03-08-2011, 11:42 PM
quarters
Thanks man.
where to cut quarter panel? freethinker52 Body - Exterior 25 10-11-2010 04:11 AM
How should I attack this? (quarter panel) lilgreenjeepyj Body - Exterior 45 12-02-2009 04:47 AM
Quarter panel help 930dreamer Body - Exterior 2 03-27-2009 06:20 AM
quarter panel. shadowismydogsname Body - Exterior 2 04-26-2008 04:52 PM
quarter panel cost? cub Body - Exterior 5 05-08-2004 04:53 AM
