Quarter skin questions... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2009, 04:53 AM
I need to replace the rear quarters on a '72 mustang coupe. I found a deal on a quarter skin for the right side, for now. It looks as if it was damaged at one point and alot of filler was used, along with it rusting out over time. I seen a post where the skin is to go over your exsisting quarter panel. Is that true? If thats the case I just wasted a $100 on this skin. I need to replace with new metal. I was told get a skin, its not a whole lot of difference than a full quarter. But im not sure if its what I really need now, maybe a full quarter is whats needed. Anyways, can I just cut out what needs to go, and weld the new skin in place? Thanks in advance..
Old 07-30-2009, 05:56 AM
ericnova72's Avatar
More for Less Racer
The skin is used to replace what you cut out of the old quarter panel. Use as much as you want or need, it's up to you based on what the car needs. Sometimes (most times) it is easier to replace one big piece instead of three or four smaller pieces.
Slapping a skin on over the old rusted and collision damaged quarter is the "butchered" way to do it.
Old 07-30-2009, 06:36 AM
deadbodyman's Avatar
Wiki Edits: 11
agreed... plus it'll trap moisture between the panels and rot out in a year...the placement of the seam is MOST important...check it out.....stepping the seam gives it extra strengh for welding and helps prevent warpage get a flanger /punch from HF for 40-50.00 punch holes every 1"or two weld the holes at every fifth hole or so to keep the panel from getting to hot ..a quick shot with a wet rag after every weld helps but the panels will require customizing ,just a little ...and get a box of drill screws so you can remove and replace the 1/4 about a hundred times before welding.Ive found that 1 1/2" down from the top edge is perfect...same on a mustang...just run a piece of 1 1/2" masking tape along the edge and trim the final amount with hand snips.its a lot of work dont expect it to be perfect the first time.some 1/4's are so far off they cant be used check out the company from the pros before buying and beware of a deal,but you might get lucky with that one
Name:	100_2037 (Small).JPG
ID:	39715   Click image for larger version
Name:	100_2055 (Small).JPG
ID:	39716   Click image for larger version
Name:	100_2062 (Small).JPG
ID:	39717   Click image for larger version
Name:	100_2111 (Small).JPG
ID:	39718   Click image for larger version
Name:	100_2083 (Small).JPG
Old 07-30-2009, 06:41 AM
Wiki Edits: 11
I use a panel ripper with an air chisel for the first cut (red car) staying away from the edges in that pic I'm using 2" tape so I can make sure I end up with 1 1/2 " for final triming
Name:	100_6306 (Small).jpg
ID:	39720   Click image for larger version
Name:	100_3813 (Small).jpg
ID:	39721   Click image for larger version
Name:	100_3832 (Small).jpg
Old 07-31-2009, 04:55 AM
Wiki Edits: 11
I'm going backwards but your very first step should be adjusting the gaps and body lines in the door and 1/4 so you'll be starting with good gaps and ending with good gaps set your jack stands on the suspension not the frame or rockers... taking the weight off the suspension will screw up the gaps... and leave the door on you'll need it as a referance point.the front of the quarter should wrap around and be welded in the jamb,it saves distorting the 1/4 when welding and a lot of unnecessary bootywork...the bottom and backside welds up like stock at factory seams,use a hammer and dollie to straiten the seams on the car and the new 1/4...there are many ways to break the factory welds but the air chisel is expensive and most important...I bought an ingersol rand at lowes for under a 100.00 with a quick release head,I've been using it for three years stedily,its a good one at a reasonable price...no need to get the very best
Name:	100_2069 (Small).JPG
ID:	39729   Click image for larger version
Name:	100_2107 (Small).JPG
ID:	39730   Click image for larger version
Name:	100_5628 (Small).jpg
Old 07-31-2009, 05:00 AM
Wiki Edits: 11
Of course,you should always wear gloves and a good helper showing up really saves the day
Name:	100_5814 (Small).jpg
ID:	39732   Click image for larger version
Name:	100_5811 (Small).jpg
ID:	39733   Click image for larger version
Name:	100_5813 (Small).jpg
Old 07-31-2009, 09:30 AM
302 Z28's Avatar
Excellent work DMB
Vince
Old 07-31-2009, 09:46 AM
Wiki Edits: 11
Thanks Vince...I only wish you still had that 69 302 it would be my next project when I get rid of this one...I used to build tri fives in Fla. but these sell better...go figure...
Old 08-01-2009, 07:35 AM
Thank You! Ericnova, and DBM!! What I asked for and then some. I plan on going to where the car is located today and dropping off this skin! Thanks again... I will come back and post pictures of progress to finished once done.
Old 08-02-2009, 08:42 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Your picking a hard car to do a quarter panel replacement on, the earlier Mustangs are alot easier. Whatever you do do not put new over old, cut it out and replace it. I started out on my 73 Mustang coupe by trying to patch just the rusted areas, it was a waste of my time. I ended up buying a repop and replaced the quarter, wheel well and trunk drop off. What you are most likely going to find is the wheel well and trunk drop off will be rusted. The thing I hate the most about 71-73 Mustang quarter panel skin replacements, is the body line by the door. The repops never match up like the originals, they just can't get it right. You can try to cut below the body line but most of the time the rust goes up higher than the body line. Then if you cut the quarter low and the wheel well is rusted you cannot access the wheel well with a low cut on the quarter. So if you replace the quarter with a skin then you will most likely have to cut it high up on the quarter panel above the body line. take a look at my project journal, it will give you a idea what is involved. I have a few details and pictures on my 73 Mustang quarter panel replacement.
Old 08-03-2009, 01:46 AM
Wiki Edits: 11
I'd like to see your pics badone... mabee help ...,I've solved that problem two ways in the past ...cameros too ...there certain spots that need special attention...I made a special tool just for reworking body lines...very ez to make
Old 08-03-2009, 08:02 AM
onebadmerc's Avatar
I have the pictures in my project journal but I don't know how to put them on this thread. The three quarter skins I have done on 71-73 Mustangs have a problem on their repo panels. The makers don't put the right curve in the panel. When you try to align up the body line on the quarter to the door it puts a bow in the panel. What I have done in the past is cut a small notch or two in the lip that welds onto the pillar support. I then push the panel inward and tack weld it. When everything aligns up I weld up the small notches and finish welding it up. If a person didn't have to cut out the body line it would make things alot easier, but Ford made a bad design. Rust usually goes up high on the quarter around the wheel well. So if you want a nice straight cut you have to go up high. Ford also put a brace attached to the outer wheel well on the 71-73 Mustangs. So if a person has to replace the wheel well on their car which will most likely be the case, they have to cut the quarter panel high. This is so they can access this brace and the wheel well lip so they can be removed. I just wish I had a bunch of pictures on this, it would be easier to describe. When he gets into his quarter on his 72 Mustang he will see exactly what is going on.
One other note, their is a small metal lip attached to the tail light panel and quarter panel, it is sandwiched in between the two. When removing the quarter panel, do not cut this small piece of metal off. This is there used to align the rear quarter up. I have a picture of it in my project journal, you will see it.
Old 08-03-2009, 03:06 PM
Born to lose,living to win
Deadbodyman: so you weld this seam right down the 1/4 panel? looks like alot of welding i will be trying 1/4 panel replacment for my frist time.
Old 08-03-2009, 04:01 PM
Wiki Edits: 11
wraith
A full quarter costs at least 600.00 and you'll lose a lot of time and it'll be a lot of unnecessary work and there will be alot more chance of screwing it up.if you screw up a hundred dollar panel you can screw it up six times and gain six times the experance for the same price(win,win)..it only looks like a lot of welding,compared to all the preperation it took to get there,the welding was a breeze...as you see I followed the curve of the panel...after trying dozens of differnt ways,I've found this way to be the easiest and best plus the fastest...heres why,no measuring I start with 2" tape to rough cut it out with an air chisel (three prong panel ripper) it takes less than five minutes to tear the old one off and get inside for a better look...after I finish cut with 1 1/2" tape and SHARP hand snips I straighten the edge with hammer & dolly then grind both sides , the undercoating must come off so the flanger can work right...the best way to grind the back side is with a 4" air grinder as slow as you can get it to go,get too disks back to back be very careful you'll have the rough abrasive facing you ...this way you can grind backwards.if you dont understand I'll post a pic of it...but anyway after stepping the edge or "flanging" that little strip becomes very strong for welding especialy with the top body line so close...putting the seam any closer will create problems getting the tools in...any lower will cause unnecessary problems also... like warpage...when I finish welding and grinding you cant tell the quarter was replaced ..and thats in bare metal...both these 1/4s took two coats of ez sand putty sanded with 80 grit not bondo or 36 grit...the body work goes so fast and is in epoxy so quick its well worth taking your time...I hate useing bondo ,sanding sucks and takes patience , for me its a waste of time...when you knock on this 1/4 with your knuckle you cant tell theres anything but metal there...with bondo, filling a warped panel, no matter how nice the bondo work is... a couple of knocks will give it away,no body believes this until I show them... sooo,just like paint work...prep is everything.welding without warpage is a step by step prosess also... you dont "JUST" weld it on theres a ton of tricks that took years to learn I'll share those too. all any one has to do is ask but first theres a lot of prep work to do on the new panel with the same amount hard learned tricks and time savers
Old 08-03-2009, 04:30 PM
Wiki Edits: 11
badmerc
I'm assuming the body line alignment problem was an in and out issue not an up and down one so it looks like youve done everthing right and of good quality the notching for an in or out adjustment is a good way to go and in the jamb too.. good thinking ...you've built it in your head first then stopped when you ran into and obstical ...perfect. you should be giving me advice. DBM
Removing quarter glass. 428ho Interior 1 08-29-2006 07:41 AM
Fender and Quarter panels for 89 Firebird 89firebird113 Body - Exterior 0 07-30-2006 12:15 PM
Interior -- Common Questions Jon Interior 0 02-12-2004 04:38 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 03:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
