Quench - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2008, 08:44 PM
1_big_jp's Avatar
Quench, 400 SBC, Head Gasket
I know this has been answered before at some point, but can't seem to find what i am looking for.
Here's the deal, I need to know which is an acceptable quench for a 400 SBC.
Here's what i have;
4.165 bore
3.750 stroke
65cc head
0 deck
26.58 dish piston
Trying to get my compression higher, without changing my pitons, what would be the thinest gasket you think i should use.
Thanks in advance guys.....
Old 02-16-2008, 09:41 PM
0.040" Is the ideal quench,You may be able to shave the heads and raise the compression to where your wanting it.
Shane
Old 02-17-2008, 02:53 AM
DoubleVision's Avatar
.040 to .060 quench is acceptable but dont go under or over these clearences. with the piston at TDC measure where the piston is in the bore then select a gasket that puts the quench within these limits.
Old 02-17-2008, 06:23 AM
techinspector1's Avatar
Wiki Edits: 326
The school of thought I learned from says 0.035" to 0.045", with the tighter spec being used for cast and hypereutectics with a tight piston to bore clearance and the looser spec for forged pistons with a little looser piston to bore clearance to allow for piston rock in the bore.
A Fel-Pro FPP-1014 would work well in my opinion. 4.200" X 0.039" with steam holes. (8.85 cc's).
This would yield a static compression ratio of 9.33:1 and in my opinion would work well with a cam along these lines.....
http://www.cranecams.com/?show=brows...tType=camshaft
quench and detonation 71javelin Engine 10 11-14-2007 07:20 PM
Quench - what would you do? dh79 Engine 13 06-08-2005 12:54 PM
Quick Quench Question arch Engine 48 08-25-2004 01:16 AM
Need help with a timing issue... 383MontecarloSS Engine 30 01-01-2004 08:24 AM
Compression Ratio advice new vortecs blndweasel Engine 8 06-11-2003 06:02 PM
